Old 04-13-2014, 06:54 PM   #1
egraham's Avatar
2016 28' International
Birmingham , Alabama
Outside TV
I am wondering if there is any way to connect my outside TV to the AS antenna ?
egraham is offline   Reply With Quote
Old 04-13-2014, 07:34 PM   #2
daveswenson's Avatar
2012 28' International
Issaquah , Washington
If you want to use the external cable or satellite outlet you could remove the outlet where your signal amp is. There should be inputs from the antenna and from the cable outlet. Remove the cable input and connect it to the amplifier output using a splitter. This will route the signal from the antenna to your external outlet. Easier to do than explain.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Sealing Windows & Caulking outside mgordon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-13-2003 12:18 PM
How to keep rodents on the outside jtetzlaff General Repair Forum 2 01-06-2003 06:19 PM
Outside Coax feed Krazykraut General Motorhome Topics 2 10-06-2002 05:39 PM
Outside handel for intrance door Sam Lawhorn Doors & Locks 2 08-20-2002 03:18 PM
outside window covers 83Excella Rock Guards, Segment & Window Protectors 2 06-30-2002 06:24 PM
