Old 04-21-2015, 04:31 PM   #15
1972 21' Globetrotter
seffner , Florida
Antenna info
May I thank everyone out there for the great info !!!
Now I can get er done and keep everyone happy !!!
joseph lamb is offline   Reply With Quote
Old 04-22-2015, 09:16 AM   #16
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by AWCHIEF View Post
Jammer, do you have a King Jack or ever used one? I have no trouble getting channels over 70 miles away. I generally receive twice as many channels as I did with the winegard Sensar antenna.
I do not but I can see the gain difference from the design.
It is likely that there was something wrong with the Sensar you replaced. The amplifiers do fail over the years.
Old 04-22-2015, 09:26 AM   #17
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I replaced the head unit only. Amp is still place and being used. Actual experience when reviewing a product is invaluable for credibility.
MICHAEL
Old 04-22-2015, 11:27 AM   #18
Wise Elder
Jammer's Avatar
2010 30' Classic
The amplifier in both the Sensar and the King are integral with the antenna head. The device with the switch and the LED, that is installed inside the trailer, is only a power supply for the amplifier on the antenna head. It works by applying a small DC voltage between the shield and center conductor of the coaxial cable leading to the antenna. The "antenna" connection of the power supply is capacitively coupled to the "output" connection so that the DC does not reach the TV.
Since you replaced the head of the Sensar with the King head, you replaced the amplifier, which had probably failed.
Hoom.
Old 04-22-2015, 04:10 PM   #19
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Originally Posted by joseph lamb View Post
Good evening all,
We have a 1972 21 foot Globetrotter . My wife is buying a new Digital TV
and according to the FCC we will be able to pick up broadcast channels in the
St. Pete area of Florida . No cable and no dish network . Just over the air .
I have zero idea on what kind of TV antenna I can buy and how I can easily
mount it on the trailer roof????? Any input is really appreciated !
Thanks , Joe
We were just down that way last week, 46 channels came in on old wineguard amplified system, even after eliminating Spanish and selling channels we had more than a couple of dozen. While experimenting with antenna found crank up or down made a difference on reception, depending on channel some were better with it down almost touching roof. Being in close to broadcasters it didn't make a difference turning 360 degrees as it did up and down. Even had Starz channels show up on the menu but they were scrambled so no viewing.
Old 04-22-2015, 04:44 PM   #20
seffner , Florida
thank you
thanks to all for all the DIRECTION !!!
Old 05-30-2016, 12:25 PM   #21
2014 25' Flying Cloud
No Specific City , US
I have a 2014 Airstream Flying Cloud with a King Antenna. I am in WV where reception is minimal. I actually only get 3 channels (2-PBS & ABC). Any suggestions on what I can do or buy to increase my coverage?
Lfoxtay is offline   Reply With Quote
Old 06-01-2016, 09:23 PM   #22
1986 31' Sovereign
Miami , Florida
Short of a satellite system, there isn't much you can do. The carrier frequencies that carry the digital data nowadays (mostly uhf freqs but some vhf) are line of sight only. And while the old analog transmissions would give you a fuzzy, blurred picture and decent sound at the fringe of the signal footprint, with digital, you either have a useable signal or you don't.
Raising the antenna would help as it expands the distance to the horizon but how are you going to do that?
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Jack Digital Over-the-Air Antenna Tallytown Audio, Video & TV 21 02-17-2013 11:19 AM
For Digital TV Signal, is Antenna Booster necessary? cmkirkland Audio, Video & TV 12 04-09-2010 01:45 PM
No antenna signal with digital TV Stream 1529 Audio, Video & TV 18 08-22-2009 05:52 PM
Best antenna for digital TV Lumatic Audio, Video & TV 14 01-18-2009 09:27 AM
Digital TV and Batwing Antenna jcanavera Audio, Video & TV 16 02-12-2008 07:09 PM
