12-02-2013, 12:44 PM
Antiquepedaler
2010 25' FB Flying Cloud
Laramie
, Wyoming
Need metal base for magnetic mount
Has anyone come up with an unobtrusive way to attach a metal base to an Airstream to seat a magnetic base Wilson Trucker antenna preferably up high?
Antique Pedaler
2021 Caravel 20 FB
12-02-2013, 12:51 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Try VHB (very high bond) tape.
Its a superduty double sided tape auto makers use to attach vechicle trim. Can be removed when needed.
Available at WalMart in the auto section. Look for 3M autobody tape. Like $3
Use this tape to adhere a metal disc to the aluminum roof.
12-02-2013, 01:00 PM
Oswego
Find a location by a vent, A/C, etc. Remove the trim to expose the area between the skins. Buy and glue in place a large magnet (observing polarity). Place antenna on outer skin above installed magnet, sandwiching the skin between the magnets.
-Rich-
12-02-2013, 01:31 PM
1974 Argosy 20
Kooskia
, Idaho
For a small Wilson (not the big trucker) I made an L shaped bracket and drilled a hole in it, and then put a bolt the size of the interior of the awning rail through it and put it in the front awning rail hole.
12-02-2013, 02:05 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Talk to your local automotive audio installer. Head units with built-in GPS receivers need to mount a magnet-base GPS antenna on the dashboard, and the installer uses a stick-on metal plate that's about an inch and a half square that comes in the kit with the head unit. The guy who installed my replacement Kenwood head unit said that he has those little stick-on steel bits (black powder-coated) in abundance, because not every install needs one, and so he saves the extras in a box in his shop. I didn't need any at the time, but he offered me a handful if I wanted them.
Your local audio installer is probably the same way, and you could get one or three just for the asking.
Because the steel plate is so small, the typical magnetic-mount antenna base will cover it completely. How discrete is that?
12-02-2013, 02:11 PM
2005 19' Safari
GLENDALE
, AZ
This is what we use. It's kind of a kluge and not very convenient to put up for an hour or two, but it works for us when we stop long enough to disconnect the Bambi from the TV:
* Flag pole mount (this goes under the tongue-jack foot): Amazon.com: Flagpole To Go Portable Flagpole Tire Mount: Sports & Outdoors
* Pool skimmer pole: Amazon.com: Jed Pool tools Inc 50-560-16 16-Feet Professional Deluxe Anodized Telescopic Pool Sk: Patio, Lawn & Garden
* Cookie baking sheet (ask your better-half for an old one that's dented, bent and/or burnt). For a cell phone frequency antenna, the baking sheet should be at least 9" in width. A large pizza pan will also work.
* TV antenna mounting brackets (you need two of these): Amazon.com: Channel Master Roof/Attic Tv Antenna Mount: Electronics
Note: The links above are provided for reference only. Some are not the exact parts I used, but they are similar. You may have to substitute whatever is available locally or online, if and when you decide to assemble something like this.
Use one U-bolt to clamp mounting brackets to the skimmer pole in opposing positions. Then, drill holes in cookie sheet, and use nuts and bolts to attach sheet to mounting brackets. Actual configuration is more apparent when you have all of the parts in hand.
Installation instructions:
1. Before disconnecting hitch, lower tongue jack foot onto flag pole mount.
2. Place magnetic-base antenna on top of cookie sheet.
3. Insert end of skimmer pole in flag pole mount. Use bungee cord or similar strap to stabilize pole against tongue jack.
4. Extend skimmer pole to raise antenna.
We run the antenna cable into our Bambi through the stove exhaust vent. However, I am thinking about a more convenient, permanent connection; preferably one that doesn't involve making a hole through an outer panel.
By the way, if you have something similar that works for you, please post details. This is just something that I pieced together, and it is probably not the best setup for everyone.
12-02-2013, 04:41 PM
Antiquepedaler
Laramie
, Wyoming
Thank you all for a great selection of answers. Now, to pick one...
Antique Pedaler
2021 Caravel 20 FB
12-02-2013, 05:37 PM
2006 25' Safari
St. Augustine
I ordered a Wilson antenna this week but a different one. What I noticed when looking up your antenna is that it has a built in ground plane so the use of metal base is not required-nice. The power jack is a good place. The only option aside from drilling that I can think of is to make a custom base that fits in a spot on your roof where you can put it up when you need it and take it down. My roof spot would be between the skylight and the fantastic vent to slide it between. You COULD attach it that way and bring your line down the refrigerator vent to the inside or just run it to the door frame with some sort of creative bundling. ?>?>
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
12-03-2013, 02:18 PM
2005 19' Safari
GLENDALE
, AZ
I would use caution when considering permanent attachment of a ferrous metal (iron/magnetic) base or plate to an Airstream's aluminum skin, due to galvanic corrosion:
Galvanic Corrosion
If you live or plan lengthy visits to areas that have lots of rain or humidity, especially coastal areas, this could lead to future corrosion problems and/or leaks.
12-03-2013, 02:23 PM
From All Over
Galvanic Corrosion
The adhesive tends to form a gasket; there's no direct metal-to-metal contact.
12-03-2013, 02:28 PM
Overland Adventurer
2009 34' Panamerica
Telluride
This is why I suggested the 3m tape....
12-03-2013, 02:34 PM
Oswego
All the magnetic antennae I have had incorporated a rubber or plastic insulator under the magnet.
-Rich-
02-07-2014, 12:27 PM
Antiquepedaler
Laramie
, Wyoming
This is the idea I ended up adopting. I 2-side taped a large steel finish washer to the roof. I was boon docking in the Valley of fire State Park above lake Meade NV. No cell service whatsoever. So I put the magnetic base Wilson trucker's antenna on the roof, plugged into a the Wilson seek, and got 4 bars.
Thanks to Atomic number 13
Antique Pedaler
2021 Caravel 20 FB
02-07-2014, 12:59 PM
2015 23' FB International
2007 19' International CCD
Steamboat Springs
I mounted mine to the batwing antenna. this gives it the height for better reception. here are pictures of an installation that I used for reference. I placed the amp in a corner of the front cabinet then ran the internal antenna to a location just below the front window next to the dinette. This dramatically improved my signal.
02-08-2014, 01:24 AM
2005 19' Safari
GLENDALE
, AZ
Steamy1, very professional looking setup.
How do you feed the antenna cable from outside through the wall or window to the amplifier?
02-08-2014, 12:05 PM
Antiquepedaler
Laramie
, Wyoming
Simple
Sometimes the simple solution is best.
Antique Pedaler
2021 Caravel 20 FB
02-09-2014, 10:30 AM
Steamboat Springs
Since I wanted to mount a Sirius sat radio antenna, I drilled a hole on the curved panel just forward of the support rib. I used the same hole for both the Wilson antenna and the sat radio. I then ran the cable in the cavity between the inner and outer skin panels to the amp. The amp is mounted in the corner of the overhead cabinet in the unused space. This was a convenient location to access power, since the radio is mounted on the other side. I installed an on/off switch as well.
02-09-2014, 10:34 AM
Steamboat Springs
The trailer is in storage, but I'll try to take a few pictures later this week and post. Once installed, it was worked very well, giving me a good signal in areas that had no bars before. Cranking it up and having the height is convenient and works well.
