Old 02-08-2014, 01:24 AM   #15
2005 19' Safari
GLENDALE , AZ
Steamy1, very professional looking setup.
How do you feed the antenna cable from outside through the wall or window to the amplifier?
Phoenix is online now   Reply With Quote
Old 02-08-2014, 12:05 PM   #16
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Simple
Sometimes the simple solution is best.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 02-09-2014, 10:30 AM   #17
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
Since I wanted to mount a Sirius sat radio antenna, I drilled a hole on the curved panel just forward of the support rib. I used the same hole for both the Wilson antenna and the sat radio. I then ran the cable in the cavity between the inner and outer skin panels to the amp. The amp is mounted in the corner of the overhead cabinet in the unused space. This was a convenient location to access power, since the radio is mounted on the other side. I installed an on/off switch as well.
Steamy1 is offline   Reply With Quote
Old 02-09-2014, 10:34 AM   #18
The trailer is in storage, but I'll try to take a few pictures later this week and post. Once installed, it was worked very well, giving me a good signal in areas that had no bars before. Cranking it up and having the height is convenient and works well.
