Old 07-08-2015, 11:19 PM   #1
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
Microwave
I'm thinking of adding a small microwave to my Bambi 16'
I've got 100W solar, 2 x 83AH Flooded Batteries and a rather monstrous 1500W Inverter,
Does the bracket kit allow for a smaller 700W type microwave ?
I'm not a fan of the GE borg cube that comes with the factory model. A little stainless Danby would be fine.
Is anyone enjoying having a microwave for anything but occasional popcorn ? Should I even bother or am I just junking up my trailer ?
timhortons is offline   Reply With Quote
Old 07-09-2015, 12:14 AM   #2
1974 Argosy 20
Kooskia , Idaho
I have a FC 20' and use my little 800 watt (input power) microwave on my 1000 watt inverter. It takes about 90 amps at 12 volts...... but..... I have two golf cart type batteries and your 16' probably only has one #24 which I doubt would not be enough to support the microwave.
I don't use it often either, just to defrost things I decide to have at the last minute. That is the way I use it at home mostly. I really don't cook in it and it rarely runs for more than two minutes. The propane stove and oven works for most things quite well.
Old 07-09-2015, 01:11 AM   #3
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
Only you can answer that question but, my take is yes, you're junking it up. A 16' is cramped for space as it is and a micro is extremely nonessential, especially if you're a camper. When you're camping 'small' think essential - footprint vs payback. I have a 19' and I'd rub two sticks together before I'd ever consider a space waster..... Just saying.
Mark,
The path not taken is the one I take.
Mj: "I'm on the road again"
Markj55 is offline   Reply With Quote
Old 07-09-2015, 04:56 PM   #4
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
I have 2 #24 batteries for about 2KWH nominal. For what it's worth. 2x not much may still be not enough.
Old 07-09-2015, 05:00 PM   #5
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
Mark,
Thanks ... I do have a medium size alumninum pressure cooker, per the suggestion in the Wallys book "5th Avenue on Wheels". Combined with the hot propane stove, speeds cooking/heating tasks up incredibly.
Besides I now have a nightmare of the MW breaking off the bracket in transit and banging around the inside of the bambi causing 1000s in damage.
microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 6 02-23-2016 10:58 PM
New Microwave Suggestions ViewRVs Stoves, Ovens & Microwaves 5 09-21-2014 12:44 PM
Anybody replace their microwave to convection microwave in a 16 sport scamp 2005 and newer - Bambi all models 0 07-10-2014 04:34 AM
removing microwave in Excella 1990 32' femuse Stoves, Ovens & Microwaves 0 03-07-2003 04:38 PM
Microwave not working ViewRVs Airstream Motorhome Forums 4 08-28-2002 02:08 PM
