Old 06-24-2013, 12:28 PM   #1
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Microphone location in factory Sony?
2012 Intl Serenity 25FB with the factory Sony audio/Bluetooth. I cannot see the microphone for Bluetooth phone and the factory says that it may still be behind the Sony and has to be pulled out to the front. Can anyone confirm this before I go find some Sony radio removal tools? Thank you.
Larry
lsbrodsky is offline   Reply With Quote
Old 06-24-2013, 01:55 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The microphone on most Sony bluetooth units is on a cord that plugs into the back of the unit. It will have a small mount attached or at least it should if Airstream included it with your trailer.
MICHAEL
Old 06-24-2013, 02:05 PM   #3
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
Larry
If you find the answer I would really like to know, too! We have a 2012 30' Serenity and can't find the microphone.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 06-24-2013, 02:40 PM   #4
lsbrodsky's Avatar
OK, I am going to pull the radio later this week and see if the mic is attached to the back. Thanks.
Larry
Old 06-24-2013, 02:57 PM   #5
dkrug's Avatar
Bad Axe , Michigan
I pulled the radio. There is a connection for an external speaker. However, it has a built in speaker. (Page 36 of owner's manual)
Debbie (who was to lazy to read it before)
1947 Spartan Manor
Old 06-24-2013, 03:00 PM   #6
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Had the same question...now I have the answer. Thanks!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-24-2013, 03:04 PM   #7
lsbrodsky's Avatar
I am not sure we are on the same wavelength. The specs for this radio indicate the bluetooth mic is external only. An earlier model had an internal mic with external being optional. AS tech support tells me the external mic should be coiled up behind it.
Larry
Old 06-24-2013, 03:47 PM   #8
dkrug's Avatar
Bad Axe , Michigan
Larry
Ahh! I didn't think to think that they would use different radios in the same year and model. I did find the wire labeled external speaker when I pulled the radio.
We did see a small (maybe 19-20') trailer at another dealer that had an external speaker but it was already installed.
Good luck!
Debbie
1947 Spartan Manor
Old 06-24-2013, 05:52 PM   #9
Hoonanea's Avatar
2012 23' International
Riverview , Florida
My 2012 International (built in November 2011) seems to have the same radio. Inside the Airstream briefcase with all of the manuals was a plastic bag that had the radio removal tools and the microphone. In my model, it was not coiled up behind the radio. I used the removal tools, pulled the radio out, and connected the mic. I still haven't found an elegant way to mount the mic but it does work.
Ho'onanea -- to pass the time with peace, ease, and pleasure.
Hoonanea is offline   Reply With Quote
Old 06-24-2013, 06:03 PM   #10
lsbrodsky's Avatar
I just bought mine lightly used and unfortunately no mic and no removal tools, just some of the missing parts, like pillows and bedspread. Strange, huh? But, I will get some removal tools and pull the radio, hoping a mic is behind there. I will report back
Larry
Old 06-24-2013, 06:09 PM   #11
Hoonanea's Avatar
Riverview , Florida
As I recall, the jack was a standard size. If he original mic is missing I suspect any mic for a imputed will work.
Old 06-24-2013, 07:08 PM   #12
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Y'all got me curious. Imdon't know where the mic is, but it does work. I'm going out to the trailer to look for it.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-24-2013, 07:54 PM   #13
dkrug's Avatar
Bad Axe , Michigan
The built in one we saw was centered over the couch on the face of the overhead locker. Ours is in the radio itself and can't be seen. (Or at least I can't)
Debbie
1947 Spartan Manor
Old 06-24-2013, 07:56 PM   #14
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Our dealer installed it coming out of the top of the cabinet that holds the blu-ray player. Looks ugly there and frankly, we haven't used it yet. I'll look to see where it's connected this weekend.
