Old 08-21-2015, 04:56 PM   #1
2004 25' International CCD
2012 25' International
slaton , Texas
jack antenna reception
?????on this Jack....any info from you experienced guys or gals to help get reception will be greatly appreciated>>>
replacing the std. wineguard antenna with a Jack head. just adding to the existing post on a 2012 International 25'....got 4 channels with the factory antenna. started out getting 1 with the Jack.. even got the same channel with the coax unplugged.. problem is that the red indicator light on the Jack will not illuminate ( no 12v power per the instr.s) ran separate coax from the plate to the antenna and still no red light. can't get Jack tech service to call me back so i'm asking for A/S support .
changed out the coax connector to the antenna, and temporarily got 12 channels. (never saw the red light on?) now I get only 4 channels, still no red light on the Jack. so i'm thinking about replacing the coax from the antenna to the inside wall plate. just wondering if the antenna is bad or the coax is iffy. anyone had similar issues? what about pulling new coax, just pull thru with a Kellems grip? any restrictions in the walls that anyone knows of?
safe travels!
gnowlin is offline   Reply With Quote
Old 08-21-2015, 05:09 PM   #2
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Do you have power to the winegard amplifier at the wall plate? Is it turned on?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-21-2015, 05:32 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
What he said, that seems to fix most reception issues people have with new antennas.
MICHAEL
Old 08-22-2015, 07:31 AM   #4
slaton , Texas
thanks guys,,,,yes I do have power at the wall plate ( light is on). I am not sure if i'm getting a good ground on the new coax connection that was installed? not too much of the mesh wire is there. I did get about 12 channels in the process,..but would up with 4 . so maybe I just need to pull new coax? just not sure about restrictions inside the wall.
Old 08-22-2015, 08:20 AM   #5
2006 19' Safari SE
Hayes , Virginia
I have same unit and am not happy with it. I was having same problem and found by tweeking the small nob on the face solved the light problem---very touchy. My problem now is sometimes antenna feels like it is binding up when turned. I do not see how the cable from the antenna to the mounted box on ceiling can be routed so it will function without sometimes slight binding. Oh, I have 3 heads for mine. Each time I called factory about a problem, they would send another head. I also found that the "on/off" switch is very delicate and breaks off very easy. Good luck....
mocus is offline   Reply With Quote
Old 08-22-2015, 02:36 PM   #6
slaton , Texas
thanks....I have a factory installed amplifier on the wall , so i'm not using the one from Jack..i get illumination there but not from the indicator on the Jack antenna itself..
I'm going to pull some more coax and see if that solves my problem..will post another reply with results.
safe travels
Old 08-23-2015, 07:26 PM   #7
If the coax fix doesn't work perhaps your amp is bad. I replaced mine with one of these. It's helpful in turning my antenna ( a Jack) for the best signal.
Winegard SensarPro TV Signal Strength Meter
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
Old 08-23-2015, 08:08 PM   #8
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
safe travels
You must replace the factory installed amplifier plate with the one provided by Jack. It is a simple, wire for wire replacement process. The Jack antenna will not work properly unless you use the provided plate.
Silverbee is offline   Reply With Quote
Old 08-23-2015, 09:47 PM   #9
Not true. Mine works great with the Winegard Sensor Pro. The Jack Replacement head does not come with an amplifier plate, only a power injector. They are emphatic that if you are retrofitting with an existing amplifier, to NOT use the power injector.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
Old 08-23-2015, 10:08 PM   #10
Before I would pull a new coax I would try running a known good cable from the antenna to the amplifier externally. And you did say your shielding is questionable. Maybe some new connectors are in order.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
Old 08-24-2015, 07:18 AM   #11
slaton , Texas
thanks to all on the reply's..so far here's an update of progress:
checked voltage of house batteries.( just to be sure I had some) and .had 13.75 VDC. then I hooked up 2 diff separate coax leads to the wall plate and then to antenna ( could not get the light on the Jack antenna to come on) unhooked from Jack and checked checked coax fitting just to see if I had voltage there. no voltage on either of the 2 cables ( assuming the center pin is the hot and the case is the ground.) took out amp plate at wall and did have 13.75 VDC at the leads on the back where they are connected to the PC board.....so got power at the back of the amp plate but nothing out the front side. looks like I need to get a new power/amp plate from Winegard. please advise if anyone has any comments
thanks in advance and safe travels.
Old 08-24-2015, 10:31 AM   #12
I would definitely look at the Winegard SensarPro. It makes it very easy to fine tune the rotation of the antenna. Good Luck.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
Old 08-24-2015, 01:53 PM   #13
slaton , Texas
winegard sensar pro
thanks, ordered one this AM on Amazon. also just put on a 4' section of coax from antenna to roof plate, this might help with ground issues. sure do not want to try and pull new coax! i'm not sure what restrictions are inside the wall. should have the new plate by Wed. and will advise results. also just noticed that I have no light on the face plate now.
Old 08-25-2015, 08:24 AM   #14
2006 19' Safari SE
Hayes , Virginia
I took tuning box from ceiling, that is supplied with antenna, and took it to the roof and connected it to the antenna directly. I got a coax cable long enough to attach from tuning unit, thru the door, to the mounted box on the wall inside (don't know what it is called). That way, I bypassed wires in the trailer. Worked for me.....
No TV reception with Winegard antenna JMBORST Audio, Video & TV 6 05-25-2014 06:44 AM
TV reception niss1679 Electrical - Systems, Generators, Batteries & Solar 21 09-11-2005 05:22 AM
lack t v reception.... norbert Our Community 1 09-02-2003 09:05 AM
TV Reception Assistance Thingy overlander63 All Argosy Trailers 4 09-01-2003 04:15 PM
Wireless Web Reception niftypkg General Interior Topics 1 11-08-2002 08:03 PM
