Old 03-30-2015, 07:57 PM   #1
2014 23' Flying Cloud
2015 28' Flying Cloud
Kalamazoo , Michigan
Inverter runs continuously????
Got my AS home today, noticed my inverter was not on??? Realized I had crossed a wire in the battery compartment. Once that was fixed the inverter fired right up. It seems to be "running" continuously. Essentially I can hear the cooling fan running/humming. Is it suppose to make a continuous noise? I have all the cushions etc out of the trailer. So everything is accentuated. Is this normal??
mwilliamsmd is offline   Reply With Quote
Old 03-30-2015, 08:06 PM   #2
1974 Argosy 20
Kooskia , Idaho
No,your inverter should not be running constantly. It takes about 1.7 to 1.9 amps just to be on, and will kill your batteries quickly unless plugged in so the converter/charger takes up the load.
Sounds like a trip to the dealer for warrantee service is in order.
Old 03-30-2015, 08:14 PM   #3
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Do you mean converter? If you do mean inverter do you mean it comes on without you turning the switch on?
Landrum is offline   Reply With Quote
Old 03-30-2015, 09:24 PM   #4
When I corrected the wiring, the 1000w pure sine wave inverter kicked on. The remote inverter switch on the wall came on and the green light turned on. the inverter has a hum to it, just like a cooling fan. That's what I'm curious about. I don't recall hearing that last year.
Old 03-30-2015, 09:52 PM   #5
1974 Argosy 20
Kooskia , Idaho
The sine wave inverter should not be on unless you deliberately turn it on.
Again, sounds like warrantee work is in order.
Old 03-31-2015, 01:03 AM   #6
Durango , Colorado
Yes, that is normal. It makes a fan sound and hum. It is fairly noisey.
You should be able to turn it off with the inverter switch. If you can then it sounds like it is working normally to me.
RVDreamer is offline   Reply With Quote
Old 03-31-2015, 08:05 AM   #7
Thanks everyone for the feedback. I'm a newbie so I'm still learning. The inverter turned off with the remote switch as it should. I was wrong in that I thought the inverter had to be on for the batteries to charge - my bad. I will only use the inverter if boon docking and need to plug in something not in the circuit. God I'm glad spring is here
Old 03-31-2015, 08:28 AM   #8
1974 Argosy 20
Kooskia , Idaho
Ah, all is well that ends well. The learning curve can be steep with a new complex product with electronics like the Airstream. Glad you found the on/off switch....LOL.
Old 10-16-2016, 10:36 AM   #9
2016 30' International
Florence , Alabama
Similar deal here - just got home with my 2016 International Signature 30. I assumed the batter disconnect switch would cut the inverter off too; but it doesn't.
joshjack is online now   Reply With Quote
Old 10-25-2016, 05:13 PM   #10
hissilver's Avatar
2018 25' International
Van Wert , Ohio
Power consumption of the Inverter
We tried out the inverter switch tonight with our single use small Kerig coffee maker. We checked the battery level, switched on the inverter, made one cup of coffee, turned off the coffee maker and turned off the inverter. When I checked the reading on the monitor we had used .5 amps on the 12 amp system. Is this level of cumsuption in line with what others have found?
hissilver is offline   Reply With Quote
Old 10-25-2016, 05:14 PM   #11
hissilver's Avatar
Van Wert , Ohio
Oppps I meant consumption....sorry for the typo
Old 10-25-2016, 07:35 PM   #12
lewster's Avatar
Naples, FL , Hood River, OR
0.5 amps for a single cup of coffee????
Sounds like your batteries are not holding charge, as they should definitely NOT get depleted that quickly by such a small load.
Was that the voltage reading right after the inverter was turned off, or was it the reading after giving them time to recover from the large transient loads that inverters will place on your battery system during use?
If it was a reading after allowing them to 'rest' a bit to recover, then I would have them checked ASAP.
Old 10-25-2016, 07:45 PM   #13
Florence , Alabama
So I'm not sure what's going on here. Amps are an instantaneous measure of power flow, not a measure of consumption. In the common plumbing analogy, amps is the amount of water flow at any given instant.
Now we talk about battery capacity in units of Amp-Hours which describes the ability of a battery to maintain a certain flow rate for a certain amount of time.
So I'm not sure what's being measured here. Did you measure 0.5Ah? So you used half an amp for an hour; or more likely something like 2 amps for 15 minutes? Or are we talking Volts which is the normal measurement of battery status? In that case a drop of 0.5V doesn't really tell us much of anything.
Old 10-25-2016, 09:32 PM   #14
lewster's Avatar
After re-reading my post, my slight confusion with the previous post is evident. Allow me to clarify.........
The poster said that he noticed a 0.5 AMP drop in his 12 amp system. I assume that he meant his '12 VOLT' system. He did not state what the amp/hour capacity of his battery system is, so in that light, his 0.5 amp use might actually be a system VOLTAGE DROP of 0.5 VOLTS. If one sees a voltage drop of 0.5 VOLTS after the minimal inverter load of making a single cup of coffee, then it would appear that his battery bank's health is in question. The only problem is that he said AMPS in his posting.
Unless he has a shunt-based battery monitor system in place, he would have no way to determine how many amps he has used from his inverter load. Voltage levels are much easier to read and measure.
We definitely need a clarification from the poster in question.
AC/heat pump runs continuously unless shut off manually lsinclair Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-13-2010 07:47 PM
Water Pump Runs Continuously craftsman Water Heaters, Filters & Pumps 6 12-01-2009 11:38 AM
Furnace fan runs constantly rogerdavis Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-10-2006 04:25 AM
Awning runs into door(s) - 16' Bambi Toasty's Dad Awnings 7 05-30-2006 05:32 PM
1988 classic 345 runs and stops howardann Mechanics Corner - Engines, Transmission & More... 4 01-05-2003 04:06 PM
