Join Airstream Forums Today
Old 06-01-2010, 06:02 PM   #1
2009 27' FB Flying Cloud
graton , California
Smile installation of rearview camera
My first time here so bear with me. Anyone have experience with passing the camera cable from the top rear mount thru the skin down to the belly of the trailer then to the front hitch area. It appears difficult as everything is closed in with riviting . The trailer is a 27ft flying cloud. Thanks qt4ca
qt4ca is offline   Reply With Quote
Old 08-20-2010, 10:13 AM   #2
fred bartlet's Avatar
2001 31' Excella
Bluffton , South Carolina
Two Camera Rearview Install
Greetings, I have this project underway for my TV and 30 S/O. The fiberglass topper was easy, I drilled and mounted the backup camera and ran the cable inside to the under body cable run. The AS is going as follow: I am removing the top center running light on the rear of the coach to use as a mounting point by using the two mounting screws to hold the new plate. I have cut and bent a small SS plate that I will mount the camera to the new plate so I don't have to drill holes in the skin. Then to run the cable, I will use the black adhesive mounting bases to run on the surface down to the bumper cover using cable ties. Then I'm going to use the surface mount screw on to run a 1/2 inch split loom tubing all the way on the belly pan, to the hitch area. This will carry the cable to the pigtail interconnection, that will carry the signal to the monitor on the TV.
I am using a two camera system from Costco, that sells the Rearview Safety camera system. I had to purchase the pigtail connection($96)from them directly, that gives you two female connectors and a double male pigtail connectors with enough cable to connect both ends. The monitor will mount on the dashboard and the control unit mounts under the dash and has the camera inputs.
I will post this install when I'm all done. Good luck
Fred Bartlett
30' S/O 01 Excella, maple floors in Galley, HA Hitch, Hyd. Disc Brakes, P3 Controller, SS Kit. Bk Splash, LED RL's, 2K/Tri Fuel Gen's & RV on TT
04 Chevy HD, CC, D/A, Curt Magnum V Rec., Full Amsoil Syn.,Dual Filters, ARE, MX Topper with lift Gate Door, Bed Rug, TPS & Bk.up Camera.
fred bartlet is offline   Reply With Quote
Old 08-20-2010, 11:28 AM   #3
Splitrock's Avatar
1976 31' Sovereign
Sioux Falls , South Dakota
Check to see if your frame is hollow. If it is, run the wire inside some pvc pipe inside the frame.
http://img.photobucket.com/albums/v1...g?t=1278182564
Old 09-08-2010, 04:34 PM   #4
2001 31' Excella
Rear vision for TT and back up camera for TV
I have completed the camera install for both units and everything seems to be in place. I chose to use the cable camera system because it's simple to connect and is interference free. This system has night vision for backing up or into a site at night!!! Nothing more exciting than a blind back up a night. On the road it will be an aid for passing and knowing when to pull in on another car or truck.
I purchased the Saftyvision system at Costco for $240 and the pig tails were $98 from Safty and materials were another $60 for electrics supply or Lowes.
Attachment 110280
Attachment 110277
Attachment 110278
Attachment 110279
Attachment 110280
Attachment 110281
Attachment 110282
Attachment 110283
Attachment 110284
Name:	Back up Camera on Topper.jpg
ID:	110287   Click image for larger version
Name:	Monitor on dash.jpg
ID:	110289   Click image for larger version
ID:	110291   Click image for larger version
ID:	110293   Click image for larger version
Name:	Pig Tail connector for TT camera.jpg
Fred Bartlett
Successful installation of wireless backup / rearview camera longdog Audio, Video & TV 29 08-22-2011 01:51 PM
GREAT Inexpensive wireless rearview camera Pete Vermont On The Road... 16 05-04-2008 02:50 PM
New Rearview Mirrors outofcontrol Classic Motorhomes 4 03-20-2008 10:02 AM
Rearview Camera Sysytem moosetags Electrical - Systems, Generators, Batteries & Solar 1 08-21-2006 03:30 PM
Back up camera installation DaveJ Airstream Motorhome Forums 12 12-26-2003 01:36 PM
