05-08-2018, 09:57 AM
2015 25' FB Flying Cloud
Hanscom AFB
, Massachusetts
Garmin BC30 backup camera install
Hello
My wife and I have a 2015 Flying Cloud 25FB and have the Garmin BC30 backup camera to go with the Garmin RV 660LMT Navigator.
I’m wondering if anyone here has installed the Garmin BC30 wireless backup camera on their rig & would be willing to share videos, photos, install instructions specific to an Airstream, and general expertise?
I’m very hesitant to put screw holes in the outer skin to mount the camera. I’ve heard that some people mount backup cameras inside the trailer looking out the window to avoid making exterior holes.
I’m also not sure about the best location for the transmitter and whether having the transmitter inside the aluminum shell would cause transmission/reception issues or where the best location is for the transmitter with an Airstream.
Any help, advice, experience or expertise would be much appreciated!
Thanks!
Dex
WBCCI#: 5772
05-08-2018, 11:03 AM
2007 30' Classic S/O
Somewhere
, South Carolina
Is you license plate in a black plastic recessed mount or other?
05-08-2018, 12:22 PM
Tampa
I just saw a post on that exact thing.
I wanted to see a photo because that's what I wanted to do.
Although I have a cabinet overhead in the rear that would be a perfect place to mount a camera, the writer had mounted his using hardware for a action mount camera like a Go-Pro.
If I can find it, I'll edit this.
Here's the post I found:
http://www.airforums.com/forums/f238...-181008-2.html
Scroll down to post #25.
05-08-2018, 01:23 PM
Somewhere
, South Carolina
BC30 is a very small camera that clips nicely onto a license plate. I mounted mine w/o drilling the aluminum exterior or any exposed cables.
05-08-2018, 02:11 PM
Hanscom AFB
, Massachusetts
Thanks for the reply! Do you have any photos of where you put the cables, the transmitter & where you tapped power from?
Thanks!
Dex
05-08-2018, 02:23 PM
Somewhere
, South Carolina
Dex,
Do you have the recessed black plastic license plate housing ?
That what mine has and I ran all from inside but about 5” of cable and camera.
I didn’t say it was easy and mine is rear bed.
My transmitter is at the front and I just run the extension cable to camera. Disconnect and stow when not used.
Gary
05-08-2018, 04:28 PM
2001 30' Classic S/O
Leander
My transmitter lays on the rear bed. Camera in the rear window.. We forgot to unplug the camera when we left. When we returned, the camera image popped up at least 200 feet away. The only time we had interference was not taking the reflectix out of the front window.
Works for us
John
05-09-2018, 11:10 AM
2018 25' Flying Cloud
Portland
, Oregon
I have the same size trailer and a 770RV GPS. I attached the camera up by the middle marker light using stainless sheet metal screws and Silkaflex sealant but double sided VHB tale and Silkaflex might have done the trick. I then ran the wire (with the Garmin extension) on the roof to right in front of the AC unit. I then mounted an all-weather box on the roof with VHB tape and Silkaflex and put the teansmitter inside. I then got the power through the solar prewire run.
Rock solid radio connection.
05-09-2018, 11:24 AM
Hanscom AFB
, Massachusetts
Thank you! This is great info. Could you tell me how you located the solar prewire run and what power you tapped into once you got through the run?
05-09-2018, 01:47 PM
Portland
, Oregon
Mine is a FC25FB Twin so for me the solar wires (labeled) and the wires from the Tow Vehicle all come together under the head of the curb side bed through an obnoxiously small little hatch (I’ve since enlarged all that.) I tied into the running lights for the trailer so to turn on the camera, you turn on the lights. If you have a queen I’m not sure where all these wires come together. I assume under the bed.
I’m adding solar right now so I’ll be changing this because to start with I’ll use the solar prewire (too lazy right now to run heavier wires but will someday.) So this means my backup camera will be on whenever the sun shines. That works for us because we don’t drive at night enough to worry about not having a camera. Eventually it will go back to the way it is when I get new 6ga wires run.
05-09-2018, 01:54 PM
2008 27' International FB
Hillsboro
I placed mine in the inside of rear window and it works great there. No holes in trailer or camera getting dirty and having to clean the lens. My transmitter is in the hall closet, It was easier for me to pick up the 12v. If I did it over again I would connect to the 12v closer to the camera.
05-09-2018, 02:14 PM
2017 23' Flying Cloud
Danville
Install of Garmin Back-up Camera
I mounted the camera on top of the plastic cover on the rear light (drill 2 holes; mounted with SS bolts and sealed with silicone). Ran the cable through the existing hole for the license plate light (no drilling) and into the bathroom wall. Went down the wall and drilled a hole in the floor. Used the extension wiring available from Garmin and ran the line underneath the trailer to the front of the trailer frame and mounted the receiver there. Wired directly to the battery with a marine switch from West Marine. Turns it off when not in use
Works great, no interference and I can use it while driving as well
Sorry, no pictures
05-20-2018, 01:39 PM
Tampa
Interesting. I was planning on just running a temp extension through the trailer and pack it up when not using it. That way I'd get the transmitter near the front window. But you say you'd go farther back?
For power, I plan on taking out one of the many USB charging ports and replacing it with a cigar lighter plug.
05-20-2018, 01:48 PM
Tampa
For those of you mounting your backup camera inside, how did you mount the camera? Specifically, the camera to the trailer? Ram mount? Action Camera mount? Home made?
I'm thinking of a plate under
the rear cabinet> Ram arm > handlebar clamp holding the camera,
but it seems like more hardware than necessary.
Have you found the transmitter to be directional? Upright or flat?
05-20-2018, 09:01 PM
Leander
If you mount the camera from under the cabinet, do you plan to shoot through the screen? If you never open the rear window, you could remove the screen and get the camera as close to the glass as possible. I would make a mount to attach to the glass to get the camera close to the glass. And have the cable come through/under the screen.
My transmitter lays flat on the bed facing up. Per the mounting instructions, the transmitter is directional.
John
05-20-2018, 09:30 PM
Tampa
Maybe. I haven't opened the window yet! I figured if I got close as possible to the glass, the screen would be out of focus.
I'm soaking this all in. How does your camera attach to your mount? I wish someone made a "action mount" with the two tabs, like on the GoPro camera shell. There's a million pieces with the three tabs to engage it, but nothing except ones with a 1/4 x 20 camera screw. I'm not sure why I'm adverse to the adhesive mounts. I know they're plenty strong. In my mind, the cabinet underside was higher, and a Ram arm gave me adjustment room close to the glass. I just hate to have a "headbuster" under the cabinet, although you sure can't walk under there.
Camera not here yet, I downloaded the manual though.
05-21-2018, 07:23 AM
Leander
Grwalk,
How did you attach the camera to the window? Do you have pictures?
John
05-21-2018, 09:27 AM
Hillsboro
Here is a picture of mine mounted in rear window.
06-12-2018, 11:18 AM
Tampa
Here's the plan.
I have the camera on a Ram arm. It will attach to the underside of the cabinet using a threaded insert (hoping to hit a solid part of the cabinet.)
In reading the manual, the camera and transmitter require 150 milliamps.
So I've ordered a adaptor to convert one of the USB outlets to a 12v. lighter receptacle. Then I'll attach a 12v. lighter plug on the power cord.
After determining a permanent place for the transmitter, I'll remove one USB and make the outlet permanently 12v. (Or put a 12v. outlet tying into the overhead cabinet where the reading lights are.)
Now the rear screen is also the emergency exit from the bedroom, so pulling the screen is a one time deal. It cannot be replaced except by the dealer so I'll try hard to keep it intact.
07-06-2018, 11:58 AM
2022 25' Flying Cloud
NCR
, Ontario
we have the garmin 760
the camera is mounted high on the rear of our 22FB,
the transmitter is taped to the back side of the shower facing the TV
the remote is power by the trailer running light which i got from the rear outside lights.
why?
when i turn on the TV headlights, the AS running lights come on and the the camera is powered.
thus i can turn on/off the camera remotely by turning on/off the TV headlights.
when it comes on , the GPS auto switches to rear view
