Old 08-22-2017, 01:18 PM   #15
1976 29' Ambassador
Dallas , Texas
Originally Posted by truckasaurus View Post
Subscribed. I'm very interested in how this develops as I need much the same for my Sovereign project. Are you going to publish with revisions? Because that would be awesome.
I can't add much but I'd be interested to know which auto transfer switch you selected as I was leaning towards a manual version after finding lots of negative reviews; and what style of fuses are preferred for breakaway switches?
William
I added a 30amp inlet in the front of the trailer and I do not want to mess with switching over the source manually. I know I wouldn't plug into both inlets but this will be able to manage it.
The ATS I bought is the Progressive Dynamics PD 5100 30 Amp Transfer Relay Part #PD5110610V.
As for fuses for breakaway, i'm not sure. I'll just go with out a fuse from the point made below.
tabney0315 is offline   Reply With Quote
Old 08-22-2017, 01:20 PM   #16
1976 29' Ambassador
Dallas , Texas
Originally Posted by HiJoeSilver View Post
This got lumped inside the quote box, just to be sure you see it.
You want to have a switch/breaker/disconnect as close as possible to the positive output(within 16-18") of on the battery itself. Before it connects to anything else or junctions. It's there to protect wiring batteries and everything else from a short with no protection. A battery short with no protection, well let me say you'd be surprised how much power they can produce.
JoeSilver, thank you very much for your input. I'll incorporate this into the design.
Old 08-22-2017, 01:31 PM   #17
1979 23' Safari
Wayland , New York
Originally Posted by markdoane View Post
I'd be reluctant to put a fuse on the Breakaway switch.
If you need it the trailer is already headed for the ditch. I wouldn't be worried about the wiring or magnets shorting out.
It's not when it's in use that you need to worry, it's when it's not. Getting a cut or frayed or broken wire with a direct short with no protection is a bad ending.
If you use a 30 or 50 amp fuse it'll allow all the current needed for a breakaway but protect you in case of a direct short.
Consider an AC circuit for a water heater. Consider using AFCI/GFCI breakers for extra protection.
Old 08-22-2017, 01:39 PM   #18
1976 29' Ambassador
Dallas , Texas
Originally Posted by SuzyHomemakr View Post
Some wiring thoughts...
I like having separate utility 110V circuits, one that runs through the inverter, one that doesn't. My Xantrex 1800w inverter can only pass so much juice through. You want to be able to run the AC/space heater and the coffee machine AND blast the stereo! (BTW: that Xantrex auto-senses whether or not you're connected to shore power, so no extra switch)
Thank you very much for your reply. If I understand your point correctly, the Victron Inverter/Charger has an internal automatic transfer switch which accomplishes the same thing. I'd try to explain it but THE expert, Lewster, has already done so.
Below is a quote from Lewster on a thread in this forum. Post #10.
http://www.airforums.com/forums/f449...ml#post1681962
"An inverter/charger operates in an entirely different way. First and by definition, an inverter/charger (there is no converter in this device) has an internal automatic transfer switch, which I will get into in a minute. When on shore power, the charger section of the unit is producing 12VDC (nominal) to charger the batteries. All DC loads are drawn directly from the batteries, unlike a converter, which will also power the DC loads when on grid. Also an inverter/charger's internal transfer switch will 'pass-thru' the incoming 120VAC from the shore power to whatever 120VAC outlets are wired to it. It will also not allow the unit to be 'inverting', as this function is strictly reserved for off-grid battery power (see below) and will essentially be in standby mode during this time.
Next, when off-grid and the inverter section of the device is activated, the unit produces 120VAC power from the battery bank and sends it to whatever 120VAC outlets are wired to it. These are the SAME outlets as described in the paragraph above. This is where the transfer switch comes into play.
The transfer switch will either be passing thru shore power if present and energizing the charging section, or will switch over to power the outlets from the batteries when off-grid and disable the charger. "
I wired in a complete second system for my second AC. Got one of those 50A to twin 30A splitters, and then wired the cable directly into a small panel with a 15A plug attached to it.
Go with stranded wire if you can, not romex. I've had so many problems dealing with the romex!
Great point. I've researched that topic at nauseam on which way to go and went with all Marine tinned stranded wire from Pacer.com. It has been more expensive for sure, but might as well do it right while I have all the access.
Wire in an exterior plug near the fresh water fill. Comes in amazingly handy!
I like using terminal strips for the 12V system- run a fat wire to a central location, install the strip, then do all of your branches from there. Case in point: I recently installed an overhead storage area above the bed. Ran a new circuit up to a terminal strip inside the cabinet, then ran separate wiring from there to the three switched lights and two fans.
Label all of your wiring as you install it, like "to inverter" "from inverter" "refrigerator", etc. Your wiring diagram is excellent, but maybe change it around so that it corresponds to actual locations in the trailer. You're probably going to need it when it's dark, you pulled in late to a campground, nothing works, and your flashlight is dead. I call this "writing notes to my future self". Being able to troubleshoot problems fast will take you from tears to toasts in no time!
Yes great point. I've done this as well. I created a diagram of the shell with each circuit run labeled by appliance and color. I've already started the wiring the AC/DC circuits just hoping for final confirmation or adjustments on how to bring it all together in where the "main components" connect.
Leave strings in the wall as you run your wire, so you can pull additional wires in the future.
Good idea. I'm going to figure out how to incorporate this now!!
I like these switches: https://goo.gl/MdRN4J
Drilling a round hole is way easier than drilling a square one.
Good luck!
ddd
Old 08-22-2017, 01:41 PM   #19
1976 29' Ambassador
Dallas , Texas
Originally Posted by Trons4u View Post
I will be doing this on my Tradewind here before long, so I'm really interested in this. What did you use to do the drawing?
I created the diagram in Adobe Illustrator. It takes some time to make adjustments so once I gather all final feedback. I'll go back and adjust.
Old 08-22-2017, 01:48 PM   #20
1976 29' Ambassador
Dallas , Texas
Ok. I like this idea.
My water heater is the Precision Temp tankless. It only runs on LP and DC for controls. Should I add a spare AC outlet where the water heater will be in case a future water heater requires AC power?
Quoted
Old 08-27-2017, 07:09 PM   #21
1976 29' Ambassador
Dallas , Texas
Bump. Any thoughts out there on the need for the booster if I have an Inverter? Any additional feedback on the diagram.
Old 08-28-2017, 05:12 AM   #22
1995 34' Limited
1978 23' Safari
Napanee , Ontario
Thank you, I will be quite interested on the final schematic layout. It is very impressive.
Bas&Wen is offline   Reply With Quote
Old 08-28-2017, 11:48 AM   #23
Burnside Bob's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel , Oregon
Wow! What a schematic!! Thanks for sharing.
Just a thought, but you might want the inline fuse for the jack at the jack. The practical reason is that you sometimes blow the jack fuse when lifting the trailer while still coupled to the tow vehicle to get pressure off hitch spring bars.
Not only have I done that, but people I've been travelling with have done that. I taped a couple extra fuses inside the propane tank lid for fast replacement. Must be a charm as haven't blown a jack fuse since.
Thanks again for sharing your diagram.
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Old 01-12-2018, 11:02 PM   #24
On adventure with H&G
MattB's Avatar
2012 30' Flying Cloud
1966 28' Ambassador
Lansing , Kansas
Is there a final diagram? I too am working on the very same lines.
MattB is offline   Reply With Quote
Texas BBQ Full Monty utee94 Off Topic Forum 145 07-07-2015 05:16 PM
1975 Overlander Full Monty dkrukosky General Repair Forum 31 04-17-2013 11:36 AM
34' Full Monty (not the funny kind) Landscraper Repairing/Replacing Floor &/or Frame 61 08-25-2012 02:47 PM
68 22' Safari - Starting the Full Monty! soldiermedic General Interior Topics 24 11-27-2006 10:54 PM
new carpet to a almost full monty Deano69LY General Repair Forum 9 11-30-2005 06:18 PM
