07-27-2009, 06:26 PM
2011 30' Flying Cloud
Norfolk
, Virginia
Digital TV reception
My 2006 International (purchased new in 2008) came with a WInegard Sensar antenna. The TV is a HD Samsung flat screen. This weekend we were not able to receive over-the-air TV signals, which I guess, means that we missed out on the analog to digital conversion.
In looking at alternatives, I'm confused (easy for me). Would like to avoid using a analog to digital converter box, so does Winegard make an antenna converter of some sort or perhaps a replacement antenna that would fill the bill? I'm told they do in both cases, but don't understand whether or not either solution would solve the converter box issue? Any suggestions? Jack
07-27-2009, 07:12 PM
1972 29' Ambassador
St. Paul
Every new trailer location requires the TV to do a complete signal scan; specifying digital only versus analog and digital scanning should be the only change after the 'change over'.
If your TV is labeled HD it should have the digital tuner built in, check the set up menus.
07-27-2009, 07:16 PM
2006 19' Safari SE
Tucson
Before getting a converter box or new antenna...get the model and serial number of your TV (from the unit or from your paper work) and go to the Samsung website to confirm that your TV is not digital-ready, and that you in fact need a converter. If your TV turns out to be digital ready, something else is going on. (Our 2006's Sony TV was not digital ready, by the way.) As Wabbiteer suggests, if your TV is HD, it should be digital ready. Also, do you have the booster engaged? (It's the little button next to your antenna in-line...it's lit green when engaged.)
07-27-2009, 07:37 PM
Norfolk
, Virginia
Now I will really show my ignorance. Assuming that my TV is a digital, do I need to be concerned about the antenna? Booster was on. Jack
07-27-2009, 07:44 PM
2006 19' Safari SE
Tucson
You will get both "yes" and "no" on that question. We still have our original bat wing antenna that we used for the analog signal...and when we can get a digital signal it's fine (in fact, amazing). There may be some signal strength advantages to a specialized antenna, but so far I have not heard anything definitive as to whether it makes a whole lot of difference. I know it's certainly not required.
07-27-2009, 07:52 PM
Norfolk
, Virginia
Thanks. This last post is very helpful. Jack
07-27-2009, 08:55 PM
I love Airstreams...
1989 29' Land Yacht
Haines City
Antennas Direct.....ClearStream 4....SWEET....claims 65 miles
i took off the old winegard on my 89 squarestream and ordered a ClearStream 4 from Antenna's Direct....Amazon.com....108.00 shipped...
now this antenna arrived today and i had a few hours to work on the airstream this afternoon...took me about 20 minutes to put it together...it was really easy...look at pics and tighten screws that was about it....
so i opened and put together the antenna...then i opened and set up the new Visio 19 that i bought last week from target for 197.00....plugged the line into the trailer and literally just placed the antenna on top of the trailer no mast or post or stand or anything....just laid it against the max air vent cover to lean it up against something....did a channel seach and hit 30 digital channels....i live almost between tampa and orlando...30 channels crystal clear...SWEET....
tomorrow i will have more time to play around with it...i plan to buy 3 five foot sections of antenna mast (Lowes $6.00 ) to get the antenna about 6.5 feet over the trailer...i plan to use ubolts to mount a short 2 inch piece of PCV pipe to rear bumper...maybe a foot or so....then drop in the mast poles with antenna on top...bungee it up real good (because it is not permanent and i dont want to put any more holes for a support piece in the shell) i just want to pull into site...drop in 1 five foot section of mast...then put the other 10 foot together with antenna on top and put all 3 pieces together...giving me a 15 foot mast with a 24 inch antenna on top...
i just dont want to pay for cable...using only 2 weekends at the park...we have roadrunner at home...and i have been up on FTA for years...but they seem to be getting hit every week or so....just too much to keep up with..
07-28-2009, 12:00 AM
2006 34' Classic S/O
Parkdale
, Oregon
We have the same antenna, and it is a little directional, as I could turn it and receive one station, but one of the others would drop out, in Portland Oregon.
We changed out the TV that came with the trailer, a Polaroid analog 19 inch, to a 26 inch HD Vizio. The antenna booster needs to be on for antenna reception to work. We receive tons of video stations and music feeds, whenever they are available.
You might check out the programming on the Samsung, and you can down load a manual from Samsung if it’s lost. Your TV should have a menu option to change from cable to antenna feed, and a search option to find available channels.
Your TV should work with cable hooked up from an outside source.
The antenna booster needs to be off.
If all is well, do a channel search.
If the TV works well, go to the next step and see if it will work off of the antenna.
Push the booster button on.
Do a channel search.
If the TV fails to work on the antenna, it may be a connection issue, or antenna orientation issue, check that it is raised, rotate 90 degrees, search again.
Hope this helps
Steve
07-28-2009, 12:11 AM
Jim Foster
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
WE use the original Wingard on our Excella and the old folding original antenna on our '65 Caravel. both give good reception.
You must know, however, that unlike analog, which allowes you to ba a little off, with digital you need to ge pretty much right on or you get nothing.
07-28-2009, 04:48 AM
Norfolk
, Virginia
Thanks aqgain for the feedback. Jack
07-28-2009, 08:09 AM
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
"Assuming that my TV is a digital, do I need to be concerned about the antenna?"
My Sensar antenna receives a great HD signal without modification. In fact, I'm at Jackson Center right now, and the reception is suprisingly good given the distance. Winegard does sell an add-on that is supposed to enhance reception. So far, it has had mixed reviews.
Winegard RV-WING Wingman Sensar Antenna Upgrade (RV-WING) | RV-WING [Winegard]
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
07-28-2009, 04:19 PM
1989 29' Land Yacht
Haines City
got the antenna up this afternoon....channel search gave me 65 digitial channels...some were duplicates and some were sales and some were in spanish...i ended up with about 40 channels that i can watch and enjoy....
07-28-2009, 04:35 PM
2005 25' Classic
Austin
We use the standard Winguard antenna with a 19" Toshiba HD TV w/DVD built in and have no problems getting multiple HD stations. As we travel around we stop and will need to do a channel scan to find the local stations. The first time I tried it, I forgot to press the signal boost on the wall plate and thought the HD signal was not going to work, but after pressing the button, it worked just fine.
Dennis
03-16-2011, 09:39 AM
Bellevue
Has anyone installed a "digital converter box" ? Our 2006' Airstream's sony tv is not digital ready.
Just wondering if anyone has installed a digital converter box and if it's complicated?
| Thread Tools |
| Display Modes |
