03-16-2011, 10:09 AM
2008 27' Safari FB SE
Mesquite
Monica -
I installed a digital converter for my mom's old TV. It's no big deal.
Cable from the wall connects to the converter. Cable from the converter goes to the TV. Plug the converter into an AC outlet and follow the instructions to set-up, program / scan for channels. The new converter box will likely come with it's own remote for changing channels. The TV will be forever on channel 3 or 4.
BTW - very cool blog. Super nice photos. If you can figure out how to cook Risotto, you can easily install the converter box.
03-16-2011, 10:21 AM
2006 28' Safari SE
Worley
, Idaho
same issue
I am going through this same process. I have verified that my Sony WEGA TV (original equipment) is not digital ready. I am ready to purchase a converter but am a little perplexed how and where to connect it. It appears that I can install the converter between the TV amp faceplate coax connector and the dual coax faceplate "cable/sat. in" coax connection. Apparently for the TV to work with the antenna, the PO installed the jumper cable between these two points so if I install the converter between these two points, theoretically, it should provide for conversion.
However, having said all of that, the diagrams in the owner's manual seem to contradict all of this. I have searched the forums and found other owners of 2006 Safari's with the same set-up as mine and they seem to use the same jumper configuration to get the TV to work on the antenna.
Before I purchase a converter box, I would sure like to know if I am on the right track.
Idmtman
2006 Safari 28' SE (Sylvia) 75th Anniversary Edition
2010 Toyota Tundra 4x4
TAC: ID-1
03-16-2011, 10:28 AM
2006 28' Safari SE
Worley
, Idaho
Attached is a picture of the faceplate configuration with the jumper cable attached as per the PO. Edit: having trouble figuring out how to attach a photo, here is the link: http://www.airforums.com/photos/show...0&userid=53021
Idmtman
TAC: ID-1
03-16-2011, 10:46 AM
2009 27' FB Flying Cloud
Siloam Springs
, Arkansas
No need to change antennas to receive Digital TV. The antenna doesn't know or care if the signal is digital or analog. Neither does the amplifer in the wingard head.
idmtman, does the cable in your photo connect between the antenna faceplate and the sat/cable "in" port? If so, yes the convertor can go between the "out" port and the TV, or anywhere along this series of connections.
As mentioned above, you will change channels on the convertor box, not the TV. Keep the convertor where it's remote can "see" it.
Regards,
Jeff & Cindy
Remi & Hunter
'09 27FB Flying Cloud
WBCCI #7026 Air #17054
"Fus-A-Lodge II"
03-16-2011, 10:52 AM
2006 28' Safari SE
Worley
, Idaho
Thanks Jeff.
I was thinking of installing the converter box along the path of the jumper cable as it currently exists. That makes the most sense to me. I appreciate the help.
Dave
Idmtman
TAC: ID-1
03-16-2011, 12:57 PM
gainesville
Went to best buy to buy converter. I bought the last one and they said they would not be stocking any. Online is the way to go, I guess. Dealer installed mine for less than 30 dollars. zz
WBCCI 3106, AIR 8784, TAC FL 14, 05 Safari 25ft LS FB, 06 Dodge Cummins 3500
03-16-2011, 01:56 PM
#21
2007 31' Classic
Athens
, Alabama
Originally Posted by J5MM
Has anyone installed a "digital converter box" ? Our 2006' Airstream's sony tv is not digital ready.
Just wondering if anyone has installed a digital converter box and if it's complicated?
Our Sony was HD compatible but not have a digital tuner built in. We thought about using a converter, they only cost $26-40 depending on where you purchase and are easy to install. But we decided to use the old sony as a Computer Monitor since it had the appropriate connections and replaced it with a nicer set. All I have to do now is replace that stupid swing out bracket with a fixed mount.
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
03-16-2011, 01:59 PM
#22
Blue Highways Explorer
King Mountain
Brought the Sony Wega into the house and hooked up to Dish satellite. Works great.
Stuffed converter box in garage.
Ordered new 12 volt tv for trailer which hooks up to the Sony 12 DVD player.
Who needs electric hookups.
03-16-2011, 02:01 PM
#23
BEWARE of the CAT
2010 31' Classic
Longmont
If your 31 is set up like ours, put in a fixed mount and you won't be able to read the comfort control.
I can't read the display on our comfort control until I move the TV out of the way.
Ken
03-16-2011, 02:35 PM
#24
1967 24' Tradewind
Estancia
, New Mexico
Winegard also makes a simple add on for the Batwing. At least Winegard claims a significant reception boost at the higher number stations using this "Wingman".
Turn left right here
03-16-2011, 03:29 PM
#25
1999 23' Safari
Perrysburg
, Ann Arbor
"Ordered new 12 volt tv for trailer which hooks up to the Sony 12 DVD player.
Who needs electric hookups. "
Mojo's got the right idea here ... "we don't need no stinkin' converter boxes!" ... especially if they need 120v. It's pretty nice to be able to boondock without generator or inverter and still run the whole shebang off the batteries and solar panels on 12v. Try it, you'll like it.
03-16-2011, 04:32 PM
#26
Bellevue
I'm going to take the plunge and buy a converter box. I'll post pictures of the process once I get it. Sounds like you and I have the same setup
03-16-2011, 04:34 PM
#27
Bellevue
Originally Posted by wayner61
Monica -
That was such a nice compliment, thank you!! Also your instructions sound pretty simple/intuitive -- I have faith I will be able to do it.!!
03-16-2011, 04:36 PM
#28
Bellevue
Let me know how that works out for you. I would love a fixed mount for our TV instead of the swing out bracket.
| Thread Tools |
| Display Modes |
