Old 08-28-2013, 09:52 AM   #1
2011 23' International
Colorado Springs , Colorado
Cooling Fan - Refrigerator
I have a 2011 23D trailer and, when I turn on the refrigerator, the external heat exhaust fan runs almost continuously, even when the outside temperature isn't particularly warm. Is there some sort of thermostat/thermocouple that can be adjusted or checked? Thanks
rkoepsell is offline   Reply With Quote
Old 08-28-2013, 09:58 AM   #2
dznf0g's Avatar
Oswego , Illinois
I believe they use a thermal switch in the chimney area. That's what I did for a mod (mine had no factory fan) I used a 140* switch, so it is on all the time except in cool/cold weather, when the burner/element is off long enough for the switch to open.
I don't know what AS uses for a switch temp, but I suppose you could move it higher or lower on the chimney to balance on/off time weighed against refer cooling efficiency, of course.
-Rich-
Old 08-28-2013, 10:58 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The switch is not on the chimney, but on the coils of the cooling unit itself.
If you really wanted to, a combination of an on-off switch and a good, quiet computer fan will help the noise level a lot.
Old 08-28-2013, 11:03 AM   #4
dznf0g's Avatar
Oswego , Illinois
I did install an on/of switch as well. I have found the fan reall isn't necessary unless ambient temp is above 80 - 85*F. Terry, could moving it around on the coils then produce different on/off times?
-Rich-
Old 03-26-2014, 09:02 PM   #5
2004 19' International CCD
Ventura , California
Hi:
We were told by our Airstream dealer than this fan (I believe he called it the reefer fan) has to be on everytime the refrigerator is on. Last weekend, we were in Joshua Tree Ntl Park and it averaged about 75 degrees. The fan ran the entire 2 1/2 days and only shut off in the middle of the night when it got really chilly. Where would I install the on/off switch? Wouldn't this be redundant since there is already a switch on the inside of the trailer? Also, it seemed that like our batteries died a lot quicker on this trip than other trips where the fan didn't run as much. We have a 19 foot Bambi CCD International.
Thank you,
Laurie
DoggerStream is offline   Reply With Quote
Old 03-26-2014, 09:17 PM   #6
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Laurie, yes you can turn the fan off with the switch inside your trailer. We turn ours off at night and open the top door while we are at our campsite for additional cooling. I'm going to add ducting from the boiler out to the door. Someone here has done it with good results. Reducing the heat in the compartment thus reducing the amount of time fan stays running.
subfan1 is online now   Reply With Quote
Old 03-26-2014, 11:24 PM   #7
1974 Argosy 20
Kooskia , Idaho
See this thread on the subject. It is long and involved.
http://www.airforums.com/forums/f425...lly-11811.html
You will find my post #96 on ducting of the boiler heat out to reduce the heat in the compartment that the fan has to deal with. Some other posts after that # have questions and my answers.
Old 03-27-2014, 05:43 PM   #8
TahoeStream'n
subfan1's Avatar
I went ahead and bought the elbows and installed them similar to what you did idroba I'll have to wait until the next trip to see what kind of difference this makes. What is the center thing that moves around that comes out of the center of the boiler? I had to move it around to get the elbow inserted flush to the top of tube.
Thanks for the tip
Old 03-27-2014, 06:58 PM   #9
1974 Argosy 20
Kooskia , Idaho
The center thing is a flue baffle which is a screw shaped piece of metal which twists the heat and exhaust gasses so they touch the side of the boiler tube and transfer heat better. I also had to fiddle around with it a bit so it would not interfere with the added ductwork.
I hope you like the modification, it took a big portion of the heat load from my upper cabinet when operating on propane. Then the quieter fan does the rest.
Old 03-28-2014, 06:23 AM   #10
1981 31' Excella II
New Market , Alabama
On the older fridges there was no fan. Why do the new fridges require a fan when the old ones did not?
Perry
Old 03-28-2014, 06:28 AM   #11
TahoeStream'n
subfan1's Avatar
I'm thinking because the older units are vented to the top?
Old 03-28-2014, 06:34 AM   #12
1981 31' Excella II
They all are because of the flu for the propane fumes.
Perry
Old 03-28-2014, 08:02 AM   #13
TahoeStream'n
subfan1's Avatar
The trailers with the two vented doors on the side are not vented to the roof therefore the need for a fan. These are the smaller 8 foot wide newer models.
Old 03-28-2014, 08:34 AM   #14
1974 Argosy 20
Kooskia , Idaho
Airstream has used several venting systems over the years. The first and best one was when the air came in through a screened opening in the belly pan and up through an opening in the sub floor, and out through a vent in the roof. Access to the refrigerator back was through a door in the outside of the trailer. Gravity did all the work to remove the refrigerator heat and it was an excellent system.
The next variation eliminated the hole in the belly pan and sub floor, and brought the cooling air through the access door to the back of the refrigerator by cutting vent holes in the door and screening it. Air still went out the roof vent. It worked pretty well.
The latest twist is to put two outside access doors on the refrigerator compartment, both with holes, to eliminate the roof vent. The air chimney is only about 3' high max and so does not work nearly as well as an 8' high stack of the old system. So, to augment the air flow, they put a fan at the top access door to move air through the system.
The problem is that the fan they use is loud and takes power all the time to run it. For us boondockers the noise is unwelcome in quiet locations and the constant battery use is not good.
The partial solution has been to replace the original fan with ones which make less noise and use less power. I have gone one step farther by directly venting the boiler heat and propane gasses from the top of the refrigerator directly to the outside so they don't add to the heat which must be eliminated by the fan in the compartment.
BTW, the earliest Airstreams with propane refrigerators used a 2" vent pipe for the propane heat and gasses from the boiler and that pipe went up through the roof like a plumbing vent. The refrigerator coil heat went directly into the rig, via a screened vent in the countertop. I had a 1960 which was set up that way from the factory.
Ask a question, get a pageant! Grin.
