Old 09-08-2015, 06:29 AM   #1
1971 31' Sovereign
jackson , Michigan
comand center
I have a 1971 sovereign and I went to check things out last week and I have no power to my command center or radio which are together every thing else works fine I checked two fuse I found behind the radio any other ideas thanks for any input.
mikedabehm is offline   Reply With Quote
Old 09-08-2015, 07:05 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Do you have another fuse panel close to your power converter?
MICHAEL
Old 09-09-2015, 04:35 AM   #3
1971 31' Sovereign
jackson , Michigan
not that I can find
Old 09-09-2015, 06:13 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you have the original Univolt blue converter the fuse panel is in an access panel on the converter. The Univolt should be in the rear roadside behind the outside compartment door or under the closet. f you have an upgrade there has to be a fuse panel somewhere.
Avion: Modifying a Center Twin into a Center Double HawkinGal Vintage Kin 19 08-23-2014 04:02 PM
1950s Center of Jackson Center PeeWee Airstream History 4 08-03-2009 08:42 PM
Small fire at Service Center at Jackson Center hohne Our Community 32 06-07-2004 10:00 PM
