Old 10-21-2018, 11:51 AM   #1
2018 25' International
Sioux Falls , South Dakota
Cool Charge lithium batteries with a Portable Generator?
Our 2018 25RB Twin has an optional 2nd a/c. And, with the addition of a hood for the exhaust fan, there is very little rooftop real estate left for solar panels.
Is it possible to use a Honda generator to directly charge lithium batteries?
I'm thinking of charging lithium batteries at convenient time that will have the least impact on other campers.
Just wondering.
DaytonaDan is offline   Reply With Quote
Old 10-21-2018, 12:06 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
You could charge thru your AS's converter if it is spec'd correctly for the Lithiums.
I went KISS, and ordered a Boondocker,, set it to 14.4v, to replace the IOTA IQ4 we were using with the Lifelines.
Consider a Zamp Portable, we use the 120w, works very well, charging thru the 7pin charge wire.
It's now available at 140w at the same price and size.
POI...Photo's before getting the Lithiums.🤓
ID:	325842   Click image for larger version
W. H. Auden
“We were young and knew nothing...now we are old and everyone else knows everything.”
RLC
"Tahawus"
Old 10-21-2018, 12:40 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
It all depends on what the charging parameters are on your lithiums (like which ones you have) and what your generator will produce. I would suggest finding out and going for the closest voltages possible.
How long can I run generator to charge batteries? wareaglewalt Generators & Solar Power 9 08-15-2017 08:48 AM
best way to charge batteries and RTR propane generator Roguegaston Electrical - Systems, Generators, Batteries & Solar 11 06-01-2016 11:22 AM
How to charge batteries from generator? xbr443 Generators & Solar Power 21 08-16-2012 08:21 PM
