Old 08-06-2018, 09:36 PM   #1
2012 Avenue Coach
Corpus Christi , Texas
Can I Paint my Sole' Roof TV Antenna?
My Sole' roof antenna works fine, but has yellowed with age.
Can I spray it with a light coat of white or silver paint without degrading reception?
Name:	Sole TV Antenna .jpg
rowiebowie is online now   Reply With Quote
Old 08-06-2018, 11:18 PM   #2
2007 22' International CCD
White paint is probably not going to be an issue. Silver paint contains aluminum particles and should be avoided, as it might interfere with reception.
Old 08-07-2018, 12:12 AM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Use a white paint formulated for plastics (all the major brands of spray paint have them.) AS mentioned above, I wouldn't expect while to have much metallic content so it shouldn't make reception worse. The usual spray-paint caveats... clean surfaces, mask everything you don't want misted with paint and use multiple thin coats with drying time in between.
— David
Old 08-08-2018, 07:57 AM   #4
2012 Avenue Coach
Bummer, I was really wanting to match the silver of the Avenue. Guess the color will go back to original white.
I have the Sole' off the roof so that makes it easy to prep and paint. On the Avenue it rides on the ventilated cowl above the recessed a/c. I removed the cowl in anticipation of replacing the a/c http://www.airforums.com/forums/f427...ml#post2139628 and the antenna is attached by an easily removed bolt through the cowl.
Old 08-08-2018, 09:34 AM   #5
DKB_SATX's Avatar
1976 Argosy 28
If you want the antenna to "blend in" more you could do a light-gray non-metallic spray paint instead of white. I just picked white because it's already that color and you want to avoid metallic colors, but a light gray that's close in value to the silver of the Avenue should help camouflage the antenna.
— David
Old 08-09-2018, 11:12 PM   #6
2012 Avenue Coach
At the height and distance from the ground, a light gray probably would do. Have to look at what Krylon has available in their plastic spray colors. Thanks
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
Rooftop Antenna Installation - Spring Mount Cellular Antenna Astw Electronics & Connectivity 4 08-04-2016 08:51 AM
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 9 03-23-2015 12:43 PM
Can roof antenna be installed at an angle? adwriter73 Audio, Video & TV 8 04-18-2011 07:28 PM
to paint or not to paint roof Angel73 Clearcoat, Exterior Paint & Trim 18 03-31-2008 07:29 AM
