Old 10-13-2019, 11:05 AM   #21
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Went on Amazon looking for the King switch and found it...
Of course I also found something else which is making me go Hmmm.
A rotating antenna by "pingbingding"
The reason I am entranced/curious is that about 2/3 of the park models and trailers in Travelers Rest & resort have something that looks like this one! (Darn, failed to get a link but this one has 1975 reviews and says it is "HDTV") neither the old winegard nor the new mushroom antenna are impressive. What do you gurus think?
Old 10-13-2019, 02:06 PM   #22
2019 26' Flying Cloud
Summerfield , Florida
Cool Pingbingding
https://reviewfinder.com/info/top-sa...-hdtv-antenna/
Can't say it would work out on a active touring Airstream Trailer. Seems more permanent use on a park model. Ugly factor is very high.
Pubtym is offline   Reply With Quote
Old 10-24-2019, 04:55 PM   #23
Smile Update
Parked in campground for first time since install of the King TV and cable switch. Cable connection was available at the docking station. Connected the outside cable and went inside to scan for stations on the front TV. BINGO! Over forty channels came through for the first time.
I believe the King switch is the correct match for the King antenna. Airstream had the Wingard switch. Very important if you do the change out, snug all the connections securely to the switch and TV.
Old 11-08-2019, 04:54 PM   #24
I looked at the King switch and didn't find one with a 12 volt plug like the Winegard.
Was this a consideration for you.
I have actually never used the 12 volt outlet on mine.
Old 11-09-2019, 07:28 AM   #25
The King switch, like the Winegard, has two terminals on the back of the switch plate (positive and negative) that are used to connect the hard wired 12V coach power wires behind the outlet. The 12V power is only needed to power the external TV antenna and that power has nothing to do with cable reception...other than the 12V button switch on the plate's outside surface must be "OFF" to get cable.
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 09:16 AM
Hot water heater does not work KAMPOTA s Water Heaters, Filters & Pumps 11 02-06-2010 03:54 PM
Suburban Nt-32 Does Not Work elliottkatz Furnaces, Heaters, Fireplaces & Air Conditioning 9 09-21-2008 02:22 AM
2000 LY 350 XL speedo does not work help !! myfirstrv Mechanics Corner - Engines, Transmission & More... 8 03-18-2008 07:08 AM
Water heater does not work on 110. thecatsandi Water Heaters, Filters & Pumps 28 07-21-2007 07:52 AM
