Join Airstream Forums Today
Old 12-12-2011, 09:02 PM   #15
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Hmm, does the weather ever get damp or wet where you live? Dampness can get into a conduit and not come out unless you take it up to the dry desert. I bet if you surveyed folks, us desert rats have less problem with GFCI's than swamp dwellers.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 12-12-2011, 10:19 PM   #16
greyzeth's Avatar
1989 25' Excella
Portland , Oregon
This swamp dweller (yes, Portland OR is swamp land) checked all that.
This still won't explain why my A/S 20amp GFI would tripp when I'm plugged into the dedicated 30amp shore power and not the 20 amp non-dedicated shore power. both are in a dry garage.
greyzeth is offline   Reply With Quote
Old 12-13-2011, 04:45 AM   #17
Leonardtown , Maryland
Try using a circuit tester in all outlets, If that proves fruitless look at A/C wiring. May need to check wiring to look for cracked or chaffed insulation.
Circuit Tester at Lowes: http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 12-13-2011, 07:34 AM   #18
HowieE's Avatar
Princeton , New Jersey
Images: 12
There is little or no chance that anything on the shore power side will have any effect on the GFI in the trailer. If you want to test this just remove the wire from the GFI in the trailer panel and then set the GFI. My guess is it will not trip.
I would again suggest you go back to my above suggestion and try to isolate the problem within the trailer. Airstream, like almost all electricians will run a wire out from a panel and connect that wire to receptacles in a chain going away from the panel. Go to the receptacle farthest from the panel and begin removing thing at that point till you have a condition where by the GFI holds. That will define the point of the problem.
WBCCI 12156 AIR 3144 WDCU TAC NJ6
2004 Excursion 4x4
1991 34 ft. Excella +150,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
My Kayak mysite.verizon.net/vze54tx9/kayak/
Old 12-13-2011, 11:24 AM   #19
Plonk
, , Minnesota
Probably because the 20 amp outlet isn't grounded the right way or the 30-to-20 amp adapter isn't grounded. Often that will mask the problem.
As Howie says, if you can't find the problem by inspection, you have to isolate it by disconnecting outlets from the string until you find the one that's causing the problem. If the problem is not due to moisture alone then it is probably because of a short between neutral (white) and ground somewhere.
Old 12-13-2011, 12:29 PM   #20
HowieE's Avatar
Images: 12
A GFI will only trip when there is an imbalance of current between the hot and neutral legs. It is designed to trip when some of the current is going through your body or any other path to ground. Now that said Jammer brings up a good point. If the 20 amp receptacle in your garage is not grounded, an open ground or a 2 prong adapter is being used to bypass the ground. Get a 3 prong tester and make sure the 20 amp receptacle is grounded. If it is then we are really at a loss.
2004 Excursion 4x4
Old 12-13-2011, 01:10 PM   #21
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Have you checked your outside 110 outlet. If there is water in there, it could cause your problem. i chased a gremlin for a week til TomW suggested I check the outside box. It was wet inside. I changed the outlet, the cover and a new gasket and problem solved.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
TAC-MS-3
KF5IMA
68 TWind is online now   Reply With Quote
Help - I'm tripping (GFI outlets that is)! 61Ambassador Electrical - Systems, Generators, Batteries & Solar 5 08-23-2011 08:55 PM
Replacement breakers on a '70 Overlander? Do they exist? rayandre Electrical - Systems, Generators, Batteries & Solar 13 08-01-2011 02:01 PM
Circuit Constantly Tripping columbus69 Electrical - Systems, Generators, Batteries & Solar 11 04-14-2011 07:08 AM
Shore power box and breakers? DanielB Electrical - Systems, Generators, Batteries & Solar 8 03-15-2011 06:33 AM
Circuit breakers in '09 International 25FB donna01 Electrical - Systems, Generators, Batteries & Solar 6 03-13-2011 02:15 PM
