Old 06-11-2016, 06:23 PM   #1
2014 25' Flying Cloud
San Luis Obispo , California
Talking Bedroom TV release on 2014 FC 25RB
Newbie here- just purchased a used 2014 AS trailer and can't figure out how to get the TV screen in the bedroom to unlock from the "storage" position. It appears to have an articulating arm. I tried to find an answer by searching for it but to no avail. Original owner never used it.
sloBill is offline   Reply With Quote
Old 06-11-2016, 06:26 PM   #2
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
If it's like ours, there is a strap that you pull down on to release it.
SeaLevel is offline   Reply With Quote
Old 06-11-2016, 06:48 PM   #3
LilBigfoot's Avatar
2016 26' Flying Cloud
London , Ontario
That's right....should be a strap behind TV....pull straight down.
You're a long time underground!
LilBigfoot is offline   Reply With Quote
Old 06-11-2016, 06:49 PM   #4
2014 25' FB International
airstream , zero
I have the same problem with our 2014 25FB. I contacted the manufacturer and was told to pull down the strap. Well, I'm either gonna break the strap or pull the setup off the wall trying that suggestion. I got shuffled off to someone else in the company and then I apparently disappeared so still don't have an answer.
I plan to take a hex wrench to the pivot bolts soon. I'm thinking I need to get to the chrome pin the strap is attached to and free it somehow.
Zeitlupe is offline   Reply With Quote
Old 06-12-2016, 11:21 AM   #5
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
My was tied in a knot and after several times I got the knot un-tied and then a easy plus down to release.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 06-12-2016, 11:38 AM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have the same setup. Try putting a little silicone lubricant on the pin and release mechanism, this will help it slide out and also stow easier.
Doug and Cheryl
Old 06-12-2016, 12:03 PM   #7
2015 27' FB International
Mary Esther , Florida
Tv arm
Yes welcome to the rest of us I messed with mine asked and was told it didn't move only to find the strap and presto it moved ,bad for not having a good procedures on how to work stuff.
Grateful2 is offline   Reply With Quote
Old 06-12-2016, 12:15 PM   #8
2016 30' Classic
Santa Rosa , California
Lightly lube the catch mechanisms with anything handy. I've used hand lotion, liquid soap, or mineral oil with great results.
Happy Trails,
Phil
phann is offline   Reply With Quote
Old 06-12-2016, 01:14 PM   #9
I knew it would be simple and make me feel like a moron for not seeing it on my own... thanks!
Old 06-12-2016, 01:44 PM   #10
RicknAnne
raschmidt1's Avatar
2016 22' Sport
Charlotte , North Carolina
Try this
Try gently pushing on the front of the TV ias you pull down on the strap -
that was my solution (after a month)!
raschmidt1 is offline   Reply With Quote
Old 06-12-2016, 02:28 PM   #11
airstream , zero
raschmidt1, THANK YOU! By pushing the top bracket arm towards the wall, I was able to release the lock pin by pulling the strap down.
Rambo Engineering - the bracket manufacturer - deserves a hearty, "Booooooo!" for apparently deciding my issue was not important enough to follow through with me.
Old 06-12-2016, 10:49 PM   #12
Petaluma , California
I had the same problem and it took me a call to the dealer to figure out. In my case, wiggling the TV a bit helps. Very poor design.
Smari is offline   Reply With Quote
Old 06-13-2016, 05:25 AM   #13
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Try lifting up on the TV while pulling
down on the strap. I learnt this after 4 years of struggling
Castaway is offline   Reply With Quote
Old 06-13-2016, 08:27 AM   #14
Native143's Avatar
2013 20' Flying Cloud
2014 16' Sport
Dunedin , Florida
Wait until you pull it all the way out and then try to figure out which bracket folds in first to get it back in place. :-)
Native143 is offline   Reply With Quote
2015 Flying Cloud 25RB tongue weight delwilli 2009-2015 Flying Cloud 16 01-24-2017 07:14 AM
Hitch Recommendations Wanted for 25RB-BMW X5d combo StillRod Towing, Tow Vehicles & Hitches 140 01-06-2015 11:40 AM
My 2015 FC 25RB AV issues Gsmblue Audio, Video & TV 8 10-01-2014 11:25 PM
Flying Cloud 25RB Twin mattesses clicker187 2009-2015 Flying Cloud 0 12-02-2012 11:56 PM
Evergreen recreational vehicles, 2012 ever-lite 25rb; airstream eBay Watch Airstreams on eBay 0 10-23-2011 04:20 PM
