Old 05-03-2015, 06:22 PM   #1
2007 25' Safari FB SE
Suburbia , Sunny So Cal
AM radio antenna advice
So as a boondocker I need really good AM radio reception.
Anyone have any suggestions for a good AM radio antenna?
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 05-03-2015, 06:40 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Is there a difference between AM and FM antenna? Mine picks up both ok.
MICHAEL
Old 05-03-2015, 06:41 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
AM? I didn't realize that still existed.
Bob Martel
WBCCI# 5766
Old 05-03-2015, 06:51 PM   #4
r carl's Avatar
Lin , Ne
Here is one but I would call these guy's as they helped me get a great tv antenna for my house.
Pixel AFHD-4 AM/FM Outdoor High Definition Radio Antenna (AFHD-4) from Solid Signal Radio Antennas&sku=5502800142
Old 05-03-2015, 06:52 PM   #5
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
We find ourselves in areas that FM is a rare opportunity. AM Radio can be spotty with the FACTORY short antenna. That is one luxury off the grid is having several good AM radio stations to listen to.
I took the factory antenna off and bought a longer whip antenna. The surprise is the threading can be DIFFERENT. Take yours into the auto parts shop to compare, but the packages are usually plastic sealed. Ask them what they would recommend. Probably the most expensive one on the rack.
What was a problem for us is we park the trailer in our garage and the garage door would scrape and bend the antenna. That was the only problem encountered.
I have a 2014 today, and debating on how to get around the taller antenna. I might have to figure out a way to tie the antenna and pull it down when parked at home. Once I have that worked out, the factory antenna is coming off. It is for local city use.
I am sure someone can suggest an antenna brand that mounts on the side, or top, that can catch lots of AM signals, day or night. No matter... find a comparable taller antenna and enjoy those stations 1000 miles from your campsite.
For some years now, the most powerful AM stations are in Spanish. I am getting to like the music but do not understand a word being said. Much like the Navajo stations traveling across Arizona. I do not understand the language, and the music seems to be all the same song with commercials in between.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 05-04-2015, 12:25 PM   #6
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
I found if I run a ground wire from the trailer too a rod 3 foot long driven into the soil almost doubles the AM stations I can pull in.. And it makes them much clearer.
As far as buying a good antenna,, good luck.. Most are China junk and hardly work out of the package.. I tried 3 brands before I got one that worked right.. Its mount is plastic and weak but still holding on..
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 05-04-2015, 12:57 PM   #7
1974 Argosy 20
Kooskia , Idaho
Here is a 50" antenna which is very similar to the ones used on the Airstreams of the 60's and 70's. Side mount, split ball unit which can be adjusted to the angle of the skin where you mount it. The 50" length is what you need for good AM reception.
Metra Electronics VDP/Antenna 44-US01R at AutoZone.com
Old 05-04-2015, 02:43 PM   #8
z , North Carolina
The best AM antenna IMHO is a three foot long piece of bare copper wire. Yup...old school baby. Nothing very thick, but stretch a piece out between two objects and plug that baby in. You would be amazed at the stations you can get. Amplitude modulation. Good ol' days of radio!
FishinHatteras is offline   Reply With Quote
Old 05-04-2015, 02:45 PM   #9
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
CCrane.com has a couple of options that you may like. They both work on the principle of inductive coupling and work great to pull in low power AM. AM propagation is best at night and better yet at night in the winter. It all has to do with shielding from the Sun. Anyhow, One device is a "Terk" AM Antenna. It is a coil of copper wire with a capacitor that is moved by you to closely match the frequency you are trying to tune in. It is directional, meaning that at max signal strength/ best reception the antenna will be perpendicular to the location of the station. You have to fiddle with it, but it is fun, cheap, and works extremely well. Its about 6 in in diameter and weighs little.
The other option is a ferrite bar ( same as the internal antenna ) set up that has a remote bar about the size of a snickers, coupled with a coax cable to an identical bar on the receiver end. Just place it in proximity to your radio.
If you are looking for a good AM radio the GE Supertuner 3 works well to pull in Distant Stations (DX) on its own.
But take a look at CCrane.com. They are a small company that loves AM / talk radio. Ive made several purchases from them and all have been superb.
Some "Blowtorch" stations that are easy to dig out are WSM 650 AM, Nashville (Grand Old Opry on Friday night, and KMOX AM 1120, St Louis (CBS Affilliate, Johnny Rabbit and "Route 66" on Sat night. On a good night on the route, you can hear that station all the way to the Grand Canyon.
Good Luck!
Clayton
NavyCorpsman is offline   Reply With Quote
Old 05-13-2015, 06:14 AM   #10
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
FM at 31"
AM at the longest length possible.
Installed location will dictate, but extending a telescopic antenna to 31" covers the most likely possibilities.
Today's car radios have crappy AM reception. The receiver is almost as important as the antenna system. TT installations may not be any better, but they could be given space available.
Hensley Arrow. 9-cpm solo, 15-cpm towing
slowmover is online now   Reply With Quote
Old 05-13-2015, 08:15 AM   #11
SteveH's Avatar
Common Sense , Texas
Ever since we got XM, I've not tuned the radio to AM or FM. It's great to choose your favorite station, and then be able to listen to it any where you go, and also be able to get news any time you want it.
I know, I'm spoiled.
Regards,
Steve
Radio Speakers but no Radio 1969 ???? tdoescher 1965-1969 Sovereign 13 04-21-2015 02:17 PM
cb radio, cassette radio jagcb750 Classic Motorhomes 14 04-19-2012 03:32 PM
Ham radio question: installation of 2m/70cm antenna in Classic 28' Dave Jenkins Our Community 4 08-17-2003 07:58 PM
amateur radio antenna for motorhome white1949 Our Community 0 01-01-2003 11:17 AM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 07:28 PM
