Join Airstream Forums Today
Old 06-24-2010, 07:58 PM   #1
'97 Excella 25
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 60
Alternative to the Batwing Antenna for HD?
Just curious, but has someone found a viable and improvement over the standard issue Winegard Batwing TV antenna for HD broadcasts. I ran into a guy in Quartzsite who owned a SOB and he was using a tall mast and an antenna he got at Radio Shack. Made me think, perhaps there's something new and improved out there to replace the Batwing.
2009 Toyota Tundra
Count me as one of those guys who makes it better than it has to be....EVERY TIME!
Bob Thompson is offline   Reply With Quote
Old 06-24-2010, 08:18 PM   #2
_
the batwing will pick up DIGITAL ota broadcasts just fine.
the signals may be more focused/directional and phase in/out during the broadcast day.
((some stations stop or alter the transmission strength diurnally))
winegard makes a small add on (takes 2-3 minutes to install without tools) that is supposed to...
INCREASE channel capture/strength in the uhf zone (higher # channels)
it's called the wingman
read about the wingman here...
having attached this add-on, i'm still not convinced it's done much.
a TALLER antenna certainly might help with ground level obstructions...
__________
HD is a different issue than digital ota broadcasting.
cheers
2air'
Old 06-25-2010, 08:01 AM   #3
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
No question, taller is better, but the last time we were in Quartsite I had no problem getting Yuma and Phoenix stations with the Batwing. (no wingman) The newer model Streams have a built in signal amplifier which I believe helps. You can also pick these up at Radio Shack.
Ahab is offline   Reply With Quote
Old 06-25-2010, 03:33 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
2000 Land Yacht 30(31') , Inverness, between the Withlachochee River and the Gulf of Mexico, Fl
Ahab has my second his answer.
I have compared signals from my house antenna and the lower antenna on the rv and found with amplifier I get signal without no signal. We are far from sending stations for the uhf bands, did much better when it was vhf. I will say when in range, HD and rotor with amp gets more channels with stations broadcasting as many as 5 from one source.
DaveFL is online now   Reply With Quote
batwing antenna 15/16" nut socket won't fit through inside skin richinny Audio, Video & TV 6 01-15-2010 08:09 AM
Batwing Antenna Leak Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 10-06-2008 08:08 PM
Digital TV and Batwing Antenna jcanavera Audio, Video & TV 16 02-12-2008 07:09 PM
Batwing Antenna Stand-Off jdalrymple Audio, Video & TV 3 06-15-2007 02:10 PM
batwing antenna for 68 GT mimibeth Audio, Video & TV 0 07-22-2006 12:58 PM
