2015 Interstate Grand Tour here! I have figured out how to watch tv with the antenna.
When I connect cable I can't get a single channel...turned the booster off and changed input on tv to cable...but nothing.
Is there something else I need to do?
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Have you done a channel scan on your television? You'll have to do it again every time you move to a new location with a new cable hookup.
Thanks for the reply, Yes change input and channel scan and still nothing.
Wondering if I need to connect something. The coax connection where the booster button is doesn't have anything plugged into it. I just turn the booster on when I use the antenna and off when I TRY cable.
2000 25' Safari
Davidson County
, NC Highlands County, FL
What you have described you are doing has made the cable work on my Airstreams. Are you sure the cable you are connecting to actually has service on it?
Alan
I don't know about Interstates, but the trailers have 2 coaxial cable inputs- one for cable, one for satellite- I don't know why-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
You should have a coax that runs from booster to the back of your TV. Mine goes in the wall and comes out to connect to the ant2 on the back of the TV. I have a 2009 classic limited.
2009 23' Flying Cloud
Egg Harbor Township
, New Jersey
I just bought a 2008' safari and had the same problem. On back of television there was two inputs for coax cable input. One for antenna and one for cable. I switched to the other input and it worked. So if you want to use antenna you have to switch back. Dan Regan
My 2005 classic does the same thing I finally bought a long coax cable and run it from the hook up in the camp ground to my TV and I watch TV It's been like that since I bought the trailer . I could just never get it to work properally .
Don
