Old 11-15-2012, 10:41 PM   #1
'96 Airstream Classic 36’ TV Motorhome
Hi Folks,
I posted this in the motorhome section and I was re directed to here.
I am new to this coach and I cannot figure out the TV. So it has two TVís. One in the front dash and one in the back bedroom on a shelf.
Neither are digital so of course they will not pick up signal. The coach has a TV antenna which I understand will pick up digital signal.
I cannot figure out where the antenna signal enters the coach and attaches to the TV. I am assuming that I will need a converter between the antenna and the TV.
Will I have to yank the TV out of the and try and Mcgyver the converter in behind the TV some how?
I see a coax cable outlet, that is powered,on the side cabinet between the two cocktail chairs but does not makes sense that you have to run a separate coax cable across the floor to the TV. I think the coax system is behind the walls.
Any ideas?
PeterK is offline   Reply With Quote
Classic Airstream motorhome crazeevw Classic Motorhomes 60 12-12-2011 01:25 PM
2003 Airstream Classic 30 Ft. EXCELLENT!!!! S2003 Airstream Classic 30 Ft. EXCELLENT! eBay Watch Airstreams on eBay 0 07-13-2011 01:00 PM
1989 Airstream 345 Luxury Edition Classic Motorhome RV eBay Watch Airstreams on eBay 1 07-02-2011 08:57 AM
Airstream Classic 36ft Motorhome EXTRA CLEAN MUST SEE eBay Watch Airstreams on eBay 0 06-05-2011 06:30 PM
Airstream Classic 36ft Motorhome EXTRA CLEAN MUST SEE eBay Watch Airstreams on eBay 0 06-02-2011 06:00 PM
