Old 04-05-2014, 12:34 PM   #1
East haven , Connecticut
Images: 12
'66 Avion T24 battery help
My batterybox is empty besides 2-4 wires an there not hooked up to the fuse panel. How does all this get hooked up an what size battery do i need? I looked at the manual because my lights an fans dont work an they say thats powered by the battery? Why? If the camper is plugged into 110.
66aviont24 is offline   Reply With Quote
Old 04-05-2014, 01:49 PM   #2
Gainesville , Florida
12volts. If you do not have a converter, the 12 volt stuff will not work. Some old Avions only had a charger, so no battery, no 12 volt. Others will chime i in if I am wrong. Jim
Old 04-06-2014, 06:28 AM   #3
Images: 12
I left the camper plugged in an went outside last night an somehow most of the lights worked. One fan worked too. I swapped out one light to a led an it doesnt work.
Old 04-06-2014, 10:01 AM   #4
Battery must have gotten a charge, either from a converter or a built in charger. Jim
Old 04-07-2014, 03:36 AM   #5
Images: 12
Like i said i dont have a battery an the wires up front arent hooked up. I replaced the 30a fuse in back an nothing worked. I went out a few hours later an stuff was on
Old 04-07-2014, 06:37 AM   #6
If it as still plugged in and 12 volt worked then you must have a converter somewhere, otherwise no lights. Some of my lights in my 64 were 12 volt and others were 120. I think this was dif in an AS. Jim
Old 04-07-2014, 06:39 AM   #7
Some of the light fixtures were powered half and half . My PO changed these all to 12 volt., eliminating 120 volt. Jim
Old 04-07-2014, 10:08 PM   #8
Images: 12
So that battery in the front only controls the lights when the camper isnt plugged in? If so ill never need the battery. Every site i go to has power.
Old 04-08-2014, 03:07 AM   #9
You need the battery for the breakaway switch. If you do not have a converter, then any twelve volt lights, water pump if you have one, possibly the refrigerator, will not work, unless you have a battery. I wish someone else who could explain this more easily would chime in. Do you have a water pump or is it a pressurized system? My 64 originally had a charger rather thana converter, I think. Jim
Old 04-08-2014, 03:08 AM   #10
You can find the right size battery at Tractor Supply. Jim
'66 Avion T24 general help 66aviont24 Vintage Kin 10 04-05-2014 12:46 PM
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
Avion T24 vintage trailer like Airstream Silverstreak Streamline Spartan El Ray eBay Watch Airstreams on eBay 0 03-04-2012 06:40 AM
Avion T24 vintage trailer like Airstream Silverstreak Streamline Spartan El Ray eBay Watch Airstreams on eBay 0 02-23-2012 01:30 PM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
