Join Airstream Forums Today
Old 01-04-2010, 04:57 PM   #1
1991 29' Excella
Livermore , California
3.15 amp fuse for Radio
I have a Sony radio, original equipment, in my 1991 29 foot Excella. A 3.15 amp fuse has blown, and I am unable to find an exact replacement. The fuse is a 5 x 30 mm glass type, but the only ones I can find are 5 x 20 mm.
Any ideas on what replacement fuse to use?
dennisv is offline   Reply With Quote
Old 01-04-2010, 05:04 PM   #2
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
the NAPA parts store here still carries older style fuses. Bring in the old one for comparison.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 01-04-2010, 05:32 PM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Does this fuse go into an in-line fuse holder?
If so and if you are unable to find the right 30mm length fuse, one, then as long as the amperage rating is the same for the 20mm one you can find, or pretty close to the same rating, then couldn't you just use a sawn- off bit of 5mm bolt x 10mm long to make up the difference between a 30mm length and a 20mm length?
Just a thought, Its the kind of mickey mouse fix I would likely try! Not teh best solution but should work ok!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-04-2010, 05:45 PM   #4
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Radio Shack, or another store like it would carry the fuse
mustang is offline   Reply With Quote
Old 01-04-2010, 05:45 PM   #5
CrawfordGene's Avatar
2008 25' Safari FB SE
Crawford , Colorado
Or, get a longer spring to make up the space.
Try radio shack for unusual fuses or a store that carries electronic parts for people who build their own stuff.
Gene
CrawfordGene is online now   Reply With Quote
Old 01-05-2010, 08:53 AM   #6
1991 29' Excella
Radio Shack did not have the replacement. They have the 20mm type.
I'll try Napa. An online search found no instances of the 30mm fuse available.
I'll either try Brian's suggestion, or cut out the old fuse holder and install one for the shorter fuse.
Thanks all for your suggestions.
Audiovox radio & cassette player Okiegent Phone, CB & Ham Radio 5 12-27-2009 07:44 PM
Electrical & Radio Interference Questions Ganglin Lights - Interior & Exterior 3 07-19-2009 08:48 AM
50 amp bussman fuse mikvw Batteries, Univolts, Converters & Inverters 11 04-27-2009 05:42 PM
'78 Tradewind labeled fuse box pics & questions BOBHASTINGS Electrical - Systems, Generators, Batteries & Solar 20 06-15-2005 06:33 PM
