Go Back   Airstream Forums > Airstream Community Forums > Full-Timing & Winter Living > Full-Timing
Old 07-13-2008, 06:15 PM   #1
Pudentane
Profile:  Currently Looking...
Dover , New Hampshire
Will truck I love pull the A/S I Love?
Hi,
I'm new here and have been looking for an RV for full-timing. It's just me - an almost retired woman and my black Lab. Today I fell in love with the 23' Safari - when I went to look at some class C's. I really like the A/S - it's so classy and high quality as opposed to the lesser construction and decor in the others. I currently have a 2002 GMC SLE shortbed 4x4 pickup with a 5.3 liter V-8 engine and a factory tow package. I love my truck - she's a cream puff, quick, plenty of power (empty) decent mileage and turns on a dime - I'd like to keep it. Is this adequate to safely tow the 23' Safari?
I don't know what the hitch on the truck is - it's whatever was part of the standard package GM put on when the truck was built.
I don't have a lot of experience with trailers - a few U-hauls over the years and a boat trailer - but it was all short distance and the boat doesn't weigh much. But how hard can it be to learn?
Any opinions and advice will be appreciated - advance thanks.
Louisa
Pudentane is offline   Reply With Quote
Old 07-13-2008, 06:37 PM   #2
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
I'm not an expert on tow vehicles, but just wanted to say welcome and ask you to post pics of your labrador in the pet section. Not only are we Airstream lovers, but a good number of us are pet lovers as well. Again, welcome!
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
cameront120 is online now   Reply With Quote
Old 07-13-2008, 06:49 PM   #3
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 58
You should have no problem with the truck, as long as it has a tow package (includes things like a transmission cooler). I would consider a new receiver for the truck, as some of them suffered rust problems, to the point of failure.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 07-13-2008, 06:50 PM   #4
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
Is it a new 23 foot Safari or a vintage Safari?
Richard
Charter Member Four Corners Unit
Old 07-13-2008, 06:52 PM   #5
overlander63
Images: 58
Oh, yeah, they did start making those again, didn't they?...
AIR#2611
Old 07-13-2008, 06:57 PM   #6
Pudentane
Dumb question - what's the receiver? the hitch has a removal ball - mounted on square stock which goes into the square "receiver?" on the truck and is held in place by a maybe 1/2 inch pin which is secured with a spring clip. It had a bit of surface rust - which I brushed off and repainted it just this week - it's not missing any metal from rust - just paint.
Old 07-13-2008, 06:58 PM   #7
Pudentane
It's a new safari - but I may look for a used one - I'm in no rush.
Old 07-13-2008, 07:04 PM   #8
overlander63
Images: 58
Yes, the receiver is the part that bolts tot he frame of the truck, and the head is the piece that slides into it, and holds the trailer ball.
It being a new(er) Safari, it should still be within rating for your truck. You would have to check the GVWR of the trailer, and the tow weight rating for your truck (usually found in your owner's manual under "towing").
AIR#2611
Old 07-13-2008, 07:40 PM   #9
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
The ball is mounted on a hitch bar. The hitch bar fits into the receiver and there is a removable pin that allows removal of the hitch bar. The receiver should be a 2" square. Also look for a 7-pin connector at the rear bumper. That tells you the truck is more than a basic model and set up for an adequate hitch. The remaining question is the presence of a tranny cooler.
5.3L? 23' Airstream? No problem mon... er, m'am!
CanoeStream is online now   Reply With Quote
Old 07-13-2008, 07:46 PM   #10
ROBERT CROSS
THE FRANTIC BANANA
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 31
Thumbs up Welcome...
Glad to have you here..
If it looks at all like this..It would be a good idea to replace.
Not just for the rust, I have seen them fail with a lot less corrosion.
Your truck should do just fine with that great little AS.
Good luck
Name:	2001 SUB #2.jpg
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 07-13-2008, 08:08 PM   #11
Mikethefixit
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
Welcome Pudentane
Definately if your hitch(receiver) looks like the one above I would replace it. There was a recall on some receivers that General Motors installed on some vechiles and they replaced them free of charge with a better one.If it comes out of your pocket,U mentioned UHAUL. They have Draw-Tite /Which is identical to Reese. I not sure what ball height U need but get the correct Drop Drawbar(thats what the ball is mounted on) and while U are there get a Weight Distrubition or Straight Line hitch. U Haul has probably the best prices of anybody. I did shop around before I bought mine.
Oh the question about the Shortbed 4x4 It will do a good job for ya.
Best of Luck on what ever you deceide. Have fun Streamin'
Roger
Mikethefixit is offline   Reply With Quote
Old 07-13-2008, 08:19 PM   #12
Pudentane
Just before dark tonight I went out and crawled under the truck and had a look at the hitch - it's in what I would call great shape - looks brand new - I've never pulled anything with this truck - and yes I believe the receiver has a two inch opening - although I didn't measure - just eyeballed it.
The fellow at the dealer's said my truck would pull it but I would need a "brake package" - but sometimes salesguys tell women what they want to hear - ya know what I mean?
Thanks for the info and the reassurances.
Louisa & Jasper Joy
Old 07-13-2008, 08:28 PM   #13
azflycaster
Phoenix , Arizona
Images: 58
I think what the guy was referring to is a brake controller. It sends power to the trailer brakes when the truck brakes are applied. Your truck is most likely pre-wired for this and installation is fairly simple. There are several brands of brake controllers on the market. Tekonsha makes the prodigy and now the P3 model. These are the most popular units today. I have an older prodigy and am very satisfied with it.
Richard
Old 07-13-2008, 08:45 PM   #14
overlander63
Images: 58
I had to have our brake controller installed on our current truck,as well as the 7 pin plug relocated to use for our trailer. If you find a trailer repair shop, they should be able to sell you a quality controller, install it, and install the connector for the trailer wiring. Most GM trucks have a blank fuse in place of the one that should go in the charge line for the trailer, it would need to be replaced with a real fuse. Location is under the hood, left side, in the fuse/relay box.
AIR#2611
I think I am in love... Rollerboy Airstream Trailer Forums 3 10-27-2007 04:08 PM
Sure would LOVE LOVE LOVE some help. Muddy Waters Tow Vehicles 44 10-18-2007 09:55 AM
We love airstreams but... fonseca Member Introductions 44 10-01-2007 02:17 PM
Always had a love for them! A737 Member Introductions 2 11-07-2006 09:36 AM
Your Going to Love This One....... Pick Our Community 2 08-21-2003 03:34 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
