Old 02-09-2010, 02:40 PM   #15
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by 2airishuman View Post
yeah THAT's a sign o'trouble.
2air'
That is an understatement. I would remove the cover on the AC panel and check the wires for signs of HEAT. Pay attention to the main power line coming to the panel.
If your lucky the extension cord you were using was small enough to have dropped the voltage across the cord and just melted that cord but check things inside to be safe.
Any sign the heat of your umbilical shows signs of heat. The molded heads on these cords is a weak point also.
2004 Excursion 4x4
Batteries and converters msmst25 Batteries, Univolts, Converters & Inverters 5 05-28-2008 07:06 PM
Beatrice Years - Years and Models to Avoid? AndyPenny Buyer Guidelines 7 10-15-2007 11:04 AM
curious about converters Annemac Batteries, Univolts, Converters & Inverters 6 08-01-2007 11:12 AM
Converters On Sale 68 Overlander Commercial Listings 18 06-26-2005 08:05 PM
When did Catalytic Converters Show Up? swebster Mechanics Corner - Engines, Transmission & More... 2 10-07-2003 05:07 AM
