Old 07-08-2011, 07:03 AM   #1
Franklin , North Carolina
Tow Rig
Assuming that we find the 28-31 ft AS we like -- what do you consider as a great (as opposed to it works, but ) tow rig? From my reading so far it looks like gvwr's top out around 8500 lbs for this length trailer. That knocks my 1500 suburban out of consideration. We travel widely and want to be able to tackle the Rockies and secondary road 12% grades with confidence.
Tarheel-2 is offline   Reply With Quote
Old 07-08-2011, 07:14 AM   #2
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Based on these requirements; diesel, 3/4 ton minimum, which in the US currently means a pick-up truck. (Too bad the 3/4 ton Burb doesn't come in deezul flavor!)
I would go 1 ton and pass right by the 3/4 ton market...nothing to be gained by going 3/4 vs 1 ton...
Good luck...this post will get WAY off topic soon!
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 07-08-2011, 07:24 AM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Welcome Aboard....
Right now it looks like you've got a horse but no cart.
IMHO....I would get the cart and then decide how much if any you need to up-grade. What TV really depends on what your towing.
Good luck in your search...
PFC.....
ďAfter all these years the reason I continue to love Thanksgiving.....I still sit at the kids table.Ē
RLC
but Iím the Husband, so we went to Cleveland.
RLC
Old 07-08-2011, 07:39 AM   #4
techiej's Avatar
2011 34' Classic
Vancouver , Washington
We really like how our Sierra 2500HD (Diesel) tows our 34' Classic Limited.
Only reason for not going to 1 ton is if it increases your registration costs in your state (which is why we didn't go to the 3500).
There was no significant difference in cost.
techiej is offline   Reply With Quote
Old 07-08-2011, 07:40 AM   #5
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Like you, we started with a GMC Sierra 1500 gas. Immediately found the hills here in the Blue Ridge of Virginia a challenge, even in 2nd gear. Searched and found a nice 2500HD 6.6 DuraMax/Allison at CarMax. Pulled 8,000 miles from Virginia to the Pacific Ocean and back last month. The diesel didn't even know the Silver Otter was back there. What a dream! Go diesel for the torque.
Greg and Linda Heuer
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
https://www.linkedin.com/in/gheuer
Silver Otter is offline   Reply With Quote
Old 07-08-2011, 08:24 AM   #6
redeagle313's Avatar
NE , Indiana
A 3/4 ton diesel will fit the bill for an 8500 pound trailer. The new GM diesels with the integrated exhaust brake are simply superb in the mountains. I used one last summer on a trip thru Yellowstone, Grand Tetons, and then to Glacier NP. Teton pass west out of Jackson WY was a great test, only had to use the brakes a couple times on the way down.
Hi Yo Silver, Away II?
looking for our next AS
TAC IN-3
AIR 7185
redeagle313 is offline   Reply With Quote
Old 07-09-2011, 01:56 PM   #7
FLMarine's Avatar
2009 27' FB International
_ , Florida
Most people don't realize how little difference there is between a 2500 and 3500. I haven't checked lately but the only real difference between my 2005 2500 dodge diesel and a 2005 3500 dodge diesel was the 3500 had an extra leaf spring.
If you are going to get a 3500 dually then take a look at a 4500 chassis cab. My older brother has a 2008 dodge chassis cab and he put a cm flatbed in the back. Needless to say his 30 ft bunkhouse tows great behind it.
I never recommend towing at the maximum limit of a vehicle. I always tow at 3/4 the maximum rating of a vehicle. A tow vehicle is something you should not skimp on. When you're in a situation that was caused by a tie vehicle that couldn't handle the situation you'll wish you spent the extra money for the better vehicle.
FLMarine is offline   Reply With Quote
Old 07-09-2011, 03:15 PM   #8
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Had I to do it over again I'd have bought a 1T versus the 3/4T we have. Same truck, only different springs. Same ride, except when loaded heavily.
Full-timing (or, a loonng vacation) we ran out of payload capacity fairly quickly with our rig (950-1100 TW) per official numbers (not the more important wheel/tire/axle ratings). The 1T makes it easier all around.
On DODGE the 2WD has both rack & pinion steering, plus independent front suspension. I would not sacrifice those two advantages to a "rating".
Hensley Arrow. 9-cpm solo, 15-cpm towing
slowmover is online now   Reply With Quote
Old 07-09-2011, 03:34 PM   #9
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
We got a good deal on a used '06 Dodge diesel a couple of years ago. I was lookin for a 2500 but the deal came on the 3500 with single rear wheels. I wouldn't waste the cost of a dualee unless you needed it for other reasons. Our SRW tows just fine. I get to cruising speed, set the cruise control and just check the mirror's every now and then to make sure the trailer is still back there. Pulls the hills with hardly needing a downshift until you get to the big ones. Go diesel, SRW, 3/4t or 1t and you won't ever look back. The 1t just gives you a little extra carrying capacity.
Good hunting.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-09-2011, 08:51 PM   #10
JFScheck's Avatar
Rockville , Maryland
Images: 33
That's why Ford offers the GVWR 10,000 lbs option (zero cost of course) on their F-350's...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 07-09-2011, 08:58 PM   #11
Sioux Falls , South Dakota
This is good to read. I've been wondering the same thing. I'm thinking that, for the two of us, a standard cab 1-ton pickup with a diesel in it would be great.
Those of you who are actually towing with diesels, what fuel consumption rates are you seeing, both with and without the trailer?
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 07-09-2011, 10:05 PM   #12
retired USA/USAF
2001 30' Excella
We have the Dodge 5.9 diesel. 2006, 3500 SRW, megacab. In march we took a 4000 mile trip from NJ to and around Fla. Over the entire trip, including a few miles without the trailer we averaged 13.8 mpg. I drive conservatively and cruise about 65 on the interstates, a bit slower off of them. That was hand calculated not using the overhead. I don't have a real good average otherwise but on the overhead it goes from 18 or so around town to 21 + on the highway.
Roger in NJ
TAC - NJ 18
Old 07-10-2011, 08:02 AM   #13
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
13.9 round trip South Jersey to Virginia Highland Haven Floyd Va. {including 50 miles not towing}. 19 mpg highway not towing. 2000 F250 7.3 Power Stroke. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 07-10-2011, 10:10 AM   #14
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Agree what what several others have said - we switched from a Sierra 1500 gas to a
Sierra 2500HD diesel when we acquired our Classic 30. Extremely happy with the combination.
I opted for the 3/4 rather than the 1 ton because I had heard several knowlegeable folk here on the forum expressing opinions that a heavy truck suspension could beat up the Airstream rather badly.
Fact or fiction? I'm still not sure. But I figured that a 1 ton would have an even stiffer suspension than a 3/4 ton, so I went for the 3/4.
So far, after a couple of cross country trips. no evidence that I can tell that the Airstream has been caused any grief! I would certainly go the same route again. Not sure I could justify the extra $$ for the diesel, but what the heck, we only get one kick at the cat (no pun intended.)
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Tow vehicle wheel base flynmike Tow Vehicles 15 05-09-2011 09:27 PM
What to tow with what hankyknot Tow Vehicles 1 05-09-2011 03:32 PM
Tow Vehicle for 27' Overlander pyrenees Tow Vehicles 9 05-06-2011 09:18 PM
