Old 07-08-2015, 12:31 PM   #29
HowieE's Avatar
Princeton , New Jersey
Images: 12
Unless you know the toll structure for a given system you are better off paying cash. Yes there are a few states that give a reduction for EZ Pass but there are a few that KILL you when using it.
All of the bridges over the Delaware between NJ and Pa charge an RV at commercial rates when using EZ Pass and that can be expensive. The bridge on route 78 should cost me $2.00 if I pay cash. I am charged $11.65 with EZ Pass. Now I can get the difference back if a call and request it. The Maine Turn Pike over charge me $22.00 the last trip. The 2 bridges on 301 in Maryland used to charge me $25.00 with EZ Pass for a $10.00 toll. They have corrected that and now charge by axles with no discount for towed equipment. $25.00 all around. They need the money
Pa. turn pike is OK and does give a discount for EZ Pass. But unless you know it can get expensive.
Most systems have a web site and post their toll structure but that may not be what you are charged so check and know before you get stung.
I had a 2 year conversation with New Jersey on the overcharging. They finally fixed it by putting a statement on the web site that all RVs would be wrongly charged while using EZ Pass. How many of the 10,000 plus RVs and boat trailers that cross that bridge a week even knew they had a web site?
2004 Excursion 4x4
Old 07-08-2015, 01:22 PM   #30
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
THANK YOU ALL!!!
...for posting this - I never even thought about needing a different EZ Pass for when I am pulling the camper. I just got off phone with Virginia EZ Pass and have one on the way. Will definitely save me some time. Also thanks for the heads up regarding overcharging - I will keep better attention to bills now.
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 07-08-2015, 01:24 PM   #31
dznf0g's Avatar
Oswego , Illinois
Discount for IPass in IL is substantial. 50%
-Rich-
Old 07-08-2015, 01:59 PM   #32
gr.austin's Avatar
2009 27' FB Classic
Sioux Falls , South Dakota
My EZpass is from Maryland and I can list as many vehicles as I want tide to the one transponder. I do not have to identify the trailer be it 1, 2, or 3 axles. So I can drive any combination of car, truck, and trailer as I can muster and the EXpass bills me accordingly. In the 15+ years that I have had this transponder (repaced once) I have never been billed out of the ordinary.
Happy traveling....
gr.austin is offline   Reply With Quote
Old 07-08-2015, 02:35 PM   #33
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Hi Howie. I use the Rt. 78 bridge a lot and found the same issue as you but ONLY if I use the high speed lane. If I use the plaza and go through the booth my Ez-pass charges me correctly. I've done this the past few times with no problems. If going south and use the DMB I've had no problems there but it's been awhile. The past few times I've taken 95 through Phila and there is no toll or go out and use I-81.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-08-2015, 04:42 PM   #34
2014 23' Flying Cloud
Rhinebeck , New York
Thumbs up EZPass for the truck/not the AS
Originally Posted by KiraR View Post
Hi:
There's no category for 'tolls while on the road' that I could see. And I'm now researching that bit for my upcoming trip.
What do you do for a toll pass if you live in, say South Dakota, but you travel EVERYWHERE else---East, West, Central, South....etc?
Advice needed and appreciated. I've spoken with NY Ezpass which covers only 14 states and I spoke with IPass from IL, and they cover only 14 states (pretty much the same ones as Ezpass).
Thanks everyone.
Kira
We have an EZPass in New York which works in NJ and MA and several other states. However we always stop at the Pay booth in lieu of easing through slowly as is normal with just the truck. Attendants generally make the charge seeing the EZPass device. I have no idea if the payment device can be issued for the TV and the TT combined. If you find out more info do let us know.
Best of luck.
Adam Geuss is offline   Reply With Quote
Old 07-09-2015, 09:45 AM   #35
Ravenna , Ohio
One thing to consider if getting EZ. Some states have a recurring charge $1 a month I think while others do not. Before I knew better I signed up for NY but at the time they had the surcharge. I learned more with some reading on line and canceled the NY account and signed up with MA as they do not have a surcharge.
I have a MH so don't have the trailer issues to contend with but if I did I would go the 2nd transponder route.
I don't understand the reluctance to having multiple transponders if you don't have to pay more.
In the 5 years I have been using EZ I only had one problem when I followed a Semi too closely through a toll both so I got a bogus charge as my transponder didn't register. I was entering the Tpk so simply picked up the receipt, got off the next exit and came right back on. kept the receipts and a couple of email to Indiana and it was resolved.
I have used EZ extensively in OH, IN, PA and IL plus one trip in MD with only the single problem stated above.
Tireman9 is offline   Reply With Quote
Old 07-16-2015, 02:06 PM   #36
jpons's Avatar
2008 20' Safari SE
Bangor , Maine
This is from the NJ Ezpass website:
I sometimes pull a camper or trailer with my vehicle. Can I still use my tag?
Yes. In this instance the equipment in the lane is designed to identify that your vehicle is pulling a trailer and you will be charged accordingly. However, if you think this will be a regular occurrence, you should call the Customer Service Center and have them send you a tag programmed for the vehicle classification you use most frequently. You should never use your tag in a vehicle type other than the one you initially requested (i.e. Car tag in a tractor-trailer).
I could not find the statement that you mention. Can you please point me to it? The reason I am asking is because I have a NJ EZPass, but I am now thinking of changing it as they charge a $1/month fee. But I also wanted to check to make sure I am not being overcharged by them.
jpons is offline   Reply With Quote
Old 07-20-2015, 08:33 AM   #37
HowieE's Avatar
Images: 12
each authority has it's own website and they go out of there way to hide the toll information as much as possible. Here are toll charts for the Delaware Manorial Bridge and the Delaware River joint Bridge Authority. I have copied the section from the DRJBA that covers RVs. Open the website and see if you can even find it.
Current Tolls
https://www.drjtbc.org/default.aspx?pageid=102
(Trailers: Automobiles with trailers in tow are $2. This rate applies for Class 11, 12, and 13 auto/trailer classifications. Class 2 trucks -- two axles -- with trailers are charged at $4 per axle ($3.60 per axle off-peak with E-ZPass). So a two-axle truck with a one-axle trailer would be the equivalent of a three-axle truck: a $12 toll, or $10.80 E-ZPass off-peak.)
I pay $2.00 with cash but $20.00 with EZ Pass
2004 Excursion 4x4
Old 07-22-2015, 08:41 AM   #38
HowieE's Avatar
Images: 12
Hows this one for governmental logic?
New Jersey charges , like most others, a $1.00 a month service fee on the account. That has been in effect for quite some time. Now they charge an additional $1.00 a month statement fee. This fee is for a computer generated e mail to let you know that your statement is available on line. My statement is always available on line.
I questioned this and was advised that the fee could be dropped and I could either receive a bi monthly e mail or snail mail notice that my statement was available on line for FREE. Now step back and figure that one out.
2004 Excursion 4x4
Old 07-24-2015, 02:39 PM   #39
Ravenna , Ohio
I chose to go with the Massachusetts program. No monthly fee for transponder and I get electronic statement. Also free.
No comment on NJ government actions or policies.
Old 07-24-2015, 03:17 PM   #40
HowieE's Avatar
Images: 12
I think you are missing the point here. The toll is set by the authority controlling the bridge/road you are on not the issuer of your E Z Pass. If that authority is overcharging that charge will flow through to you no matter who you ar using.
You have to know or you have to pay.
2004 Excursion 4x4
Old 07-24-2015, 03:34 PM   #41
retired USA/USAF
2001 30' Excella
So Howie, Does that mean that they will charge you $1 to send you an e-mail notification that has no cost to it but will send you a mail statement that will cost them postage for free ????? I agree that makes no sense at all but then again welcome to the great state of NJ. I just checked my EZ-pass usage. I crossed the Delaware R in May using Rt. 78 with my truck & trailer. Going through the toll plaza using my EZ-pass I was correctly charged the $2 toll. This was NOT the high speed lane but the plaza lanes. As I've said before if I use the high speed lane they hit me for $13 I think. The commercial truck rate.
Roger in NJ
TAC - NJ 18
Old 07-24-2015, 03:35 PM   #42
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
NJ EZPass
Holy moly, I just looked at my EZPass statement....pulling thorough Chicago May 31, June 1, when I visited the ZipDee factory. My Garmin routed me through downtown and thus, my trip through Chi town cost me $36.20 in tolls.....
I may have to check this out....but, I think I will attempt to bypass the toll roads on my next trip....Or route myself around all the Chicago stuff....
But, NJ EZPass only charges me $1.00 per month administrative fee.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Making a living while traveling yukionna On The Road... 17 04-23-2013 11:47 PM
Tolls In Maine fastrob On The Road... 22 02-23-2009 04:40 AM
EZ Pass and double tolls HowieE Off Topic Forum 18 05-12-2006 08:21 PM
Do you use your LP refrig while traveling? John Community Polls 19 07-23-2005 09:28 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
