Old 08-30-2016, 03:22 PM   #1
2005 28' International CCD
Wailuku , Hawaii
toilet
we have a 2005 International (28') permanently positioned on our property. We will be living in it for a year while we build our home - then it will be guest quarters. we want to completely remove the toilet and storage tank and replace with a regular toilet with a direct connection to our water and septic system. Any problems with doing that? Anyone out there done this?
Maui Bob is offline   Reply With Quote
Old 08-30-2016, 09:35 PM   #2
1979 23' Safari
Wayland , New York
No problems doing it. What is the driving force behind it though. Don't like the operation of the RV toilet?
Seems like a lot of extra work than just connecting the trailer drain to the septic inlet and dumping them every few days.
With no trap between the septic line and gray and or black tank the septic gasses can flow back up the sewer line through the tanks and up out the roof vent which can cause odor problems through roof vents or windows at times. Normally closed dump valves prevent this when connected to sewer.
I would recommend finding a place to put the tank and rv toilet so you can put them back someday if you want to sell the trailer down the road
Old 08-30-2016, 10:50 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Even with a residential toilet you will need a vent stack of some sort. Every home has at least one vent stack, many have multiple vent stacks depending on the floor plan.
Toilet seal for vintage toilet thinktankair Waste Systems, Tanks & Totes 0 06-09-2014 01:37 AM
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 07:12 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 04:52 PM
Thetford Toilet Repair??? Galaxy Low Profile ViewRVs Sinks, Showers & Toilets 11 05-03-2010 04:27 PM
Raise the toilet FrankR Sinks, Showers & Toilets 0 03-15-2002 10:57 PM
