Old 09-14-2008, 07:11 PM   #659
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I took care of a few items over the last few days, such as finding a new home for the old truck, and checking over the new truck. I removed the brake controller from the old truck, and found there were a few things that seem to be done to make a bake controller work in the new one. It is what we here call a "contractor's special", as it has the big engine, automatic transmission, heavy duty suspension, and little else. Then again, I don't have to worry about the power windows not working, or the power door locks failing, or the power seat shorting out, or the CD player not working, because it has none of these things.
I also moved the cap (topper) from the old truck to the new one, and discovered that even though the new truck is a lot bigger overall, the bed is several inches narrower, especially at the rear.
We cleaned most of the old cigarette detritus from inside the new truck. It seems the original owner never met a cigarette he didn't like (and smoke). I feel like I'm driving a 6000 pound ashtray.
The trailer hitch receiver was a source of concern, as this year had issues with them failing at the most inopportune moments (like when towing a trailer). I crawled under the truck and verified it had been replaced. Whew! Then I looked more closely. One of the welds is cracked, rendering the receiver unsafe for use. Crap!
Over the next several days I hope to get everything ready to go. Here is a couple of pictures of the old and the new:
ID:	67381   Click image for larger version
Old 09-15-2008, 06:00 PM   #660
Well Preserved
1993 21' Sovereign
Now, on to more issues...
I bought the trailer tow harness kit required for this year and model truck, and hooked it up. For some reason, there was no power to the harness, even with the new maxi-fuse installed. After much cursing and gnashing teeth (my teeth are getting pretty worn down from all this gnashing) and several phone calls, I have discovered that the truck managed to leave the factory without the computer being programmed to operate the trailer tow package. Chevrolet will be happy to reprogram it for me, for a nominal fee ($175, maybe more). I have decided to go low-tech, and wire everything up as if it was 1977 again... It seems a waste of time, materials, and resources to bypass perfectly good stuff, but my $175 can be better spent on other things we really need, like a new trailer receiver ($169). I've also discovered I can't even upgrade the factory radio (am/fm), because the onboard computer will think the truck has been stolen by having a non-OEM radio installed, and shut down, again requiring reprogramming the computer...
Old 09-16-2008, 08:59 AM   #661
eikel1we's Avatar
1975 25' Tradewind
, Michigan
Send a message via AIM to eikel1we
My dad used to say, "Life's great .... if you don't weaken!" Terry, you and Marie have proven to be pretty sturdy, but geez -o- pete - enough is enough already!!! We're going to have to start calling you Murphy, as in Murphy's Law! Maybe Murf for short.
sue
ps The new truck is sharp! and do you still have the B-van?
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
2004 GMC Yukon XL 2500
Michigan - "middle of the mitt"
eikel1we is offline   Reply With Quote
Old 09-16-2008, 11:33 AM   #662
Well Preserved
1993 21' Sovereign
Thank you, and yes, we still have the B-van.
Old 09-16-2008, 11:44 AM   #663
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Is there power to the fuse? If not, if you power up the fuse from the battery it may bring the harness alive.
Diesel1 is offline   Reply With Quote
Old 09-16-2008, 11:48 AM   #664
Well Preserved
1993 21' Sovereign
Yes, there is power to the fuse (40 amp maxi fuse). It seems the BCM is what controls where the power is routed, and it was never "flashed" for the tow package it had. I have to take it to the dealer for warranty work tomorrow I'll see if I can talk one of the techs into reprogramming it for me as a professional courtesy. Maybe buy him lunch or something...
Old 09-16-2008, 12:16 PM   #665
Diesel1's Avatar
1967 24' Tradewind
If the bribe does not work ,try to find the relay that the 40 amp fuse runs through. I think that the PCM would switch the relay on, so if you can ID that relay you could switch it on with battery power and that should power up the harness.
Old 09-20-2008, 06:14 AM   #666
sd90mac's Avatar
Yes, we still have the b-van, and I drive it all of the time.
I broke the radio already. I put the conversion cassette for my mini Ipod in, so I can listen to my favorite music, and it's stuck. When I say stuck, I mean, impossible to remove stuck. Never to come out again stuck. My son wants to know how in the devil did I get it stuck. Me too. Terry has tried everything to get it out.
The worse part is it skips. The music will play for 3 seconds, then silence for 2 seconds. It drives me and Sophie nuts! The cassette drive needs to be cleaned, but we can't get the Ipod conversion cassette out.
He-- with it, I will visit yard sales, and send Terry to local junk yard to find one, and we will replace it then break the old one and get the cassette out.
Other than that, we are on the less than a week countdown to leaving for Ca.
Marie
When people lie to you, and refuse to honor their word, don't regret trying to follow a dream, new adventures and friends await you.
sd90mac is offline   Reply With Quote
Old 09-20-2008, 06:20 AM   #667
Well Preserved
1993 21' Sovereign
Things happen fast at our house...
I am temporarily among the ranks of the unemployed, but that doesn't mean I'm not busy. I loaded up my tools, and departed work around 5:30 last evening. It took almost an hour to get out of the place, no one really wanted me to leave. Interestingly, the entire sales staff walked out (as in quit) earlier this week. Seems I am not the only one that had issues with upper management.
Now I can spend some time checking the wiring in the new truck. I have checked with my friends at GM, and they tell me there is no reason to brake controller and charge line don't work. It is not involved with any computer, which is good, as I have never had to have a computer reprogrammed to tow a trailer before.
After that, I have to go back to Firestone (shudder) for another tire. When I bought the truck, it had no spare. I got a spare wheel, but it had no tire on it. I am not going 3000 miles with no spare, that will be asking for a flat tire, probably 400 miles from any place that sells tires. I'll let you know if any further drama unfolds getting (hopefully) the last tire...
Old 09-20-2008, 06:23 AM   #668
sd90mac's Avatar
and fix the radio in the van.
Marie
Old 09-20-2008, 01:01 PM   #669
Well Preserved
1993 21' Sovereign
.....This just in.....
I have the spare successfully mounted in the truck, the people at Firestone couldn't figure out the lift mechanism for the spare . So, after I got home, and put the spare where it goes, I turned my attention to the wiring. I pulled stuff apart there should be no reason to pull apart, and lo and behold, there were 3 wires not hooked up to the main fuse panel under the hood. There was one wire not connected to another one, and two wires not mounted on the lugs for the power bus. Naturally, I didn't have the proper sized nuts (I only have a few hundred lying around, none in those sizes), so off to Ace Hardware I went. 65 cents later, I had the correct retaining nuts, and everything works like it should.
Later, I'll be installing the license plate light and bracket for Bertha. The light was out, and when I tried to disassemble it to replace the bulb, it crumbled to dust in my hands. The only thing holding it together was the chrome.
And so it goes...
Old 09-21-2008, 09:07 AM   #670
1998 28' Excella
Dolores , Colorado
Marie are you driving the B-Van and Terry pulling the trailer with his new pick-up to CA?
Lou
bolou97 is offline   Reply With Quote
Old 09-21-2008, 10:27 AM   #671
sd90mac's Avatar
Lou
Yes, I am driving the guest house and Terry is pulling the coach behind his new toy, uh truck.
He has the Garmen in the truck, so if we get lost it's not my fault. Of course he never gets lost. No really he doesn't. I think he has a Garmen in his brain. The man can find any place we are going.
I detailed the van yesterday, and the dog this morning.
Sophie was funny, she heard the water running when I called her she took off and hid behind Terry. He picked her up and put her in the tub, she looked at him as if to say "traitor". She does smell better, and her coat is soft.
So we are winding down to launch time Saturday morning. Last day at work for me is Thursday, Friday is finish laundry, load van, and a few other odds and ends.
Oh Yea, the radio in the van was fixed yesterday, Terry got the ipod thingy out. Had to take the radio out to do it, but he fixed it! Thanks Terry.
Marie
Old 09-21-2008, 10:34 AM   #672
Well Preserved
1993 21' Sovereign
Why I hate vinyl seats...
This morning started off clear and sunny. I had a couple of errands to run, so I hopped in the new truck (trying to put some miles on it so I can see if there are any real "issues"--so far, so good), and headed off to the store. It was a warm morning, so I put on shorts instead of the jeans I normally wear. First place I stopped, I went in, picked up a few items, and went to stop 2. Stop 2 happened to position the truck so the driver's seat was in direct sunlight. Florida sun is hot, and Florida sun in Summer is hotter. Add to that I had the windows rolled up (Florida in Summer can become very wet, very fast, as in rain), and taking longer than I thought I would in the store.
Bear in mind, every vehicle I've owned for the past 20 or so years has had cloth seats--for a reason. The new truck has vinyl seats. Vinyl seats tend to get very hot when exposed to direct sunlight. I came out of the store, unlocked the door, and hopped into the irradiated driver's seat. The vinyl seat that had been in the sun for an extended period. While I was wearing shorts.
Holy Crap!!!!
I thought I'd sat on a pile of nuclear waste, or at the very least, molten lava! I think the back of my legs are fused to the seat now... I hope the burning sensation will stop soon! Wow! I don't think I'll do that again for a while...
1974 sovereign, travel
The adventure begins.... in more ways than one! katzklaw 1960 - 1964 Overlander 157 12-21-2014 03:54 AM
Our full time adventure begins on Monday! zombyw00f Full-Timing 18 12-13-2007 09:38 PM
"The Tube's" Adventure Begins myboyburt Cleaning, Stripping & Polishing 44 07-11-2006 02:50 PM
Off to LA....The Adventure begins JodynJeep On The Road... 29 11-20-2003 12:23 PM
albert's excellent adventure john hd Our Community 13 08-06-2003 07:58 PM
