Old 06-09-2008, 07:34 AM   #547
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Looks like this is your week for upgrades.
www.nesa.org
Air No. 6427
Old 06-09-2008, 07:54 AM   #548
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Yes, and maybe I'll be able to upgrade Marie's overhead bedroom tambours this week, too.
Old 06-09-2008, 08:31 AM   #549
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Gee, your reading light lenses look amazingly "not yellowed"...unlike mine. Are they originals?
I really like the florescent retrofit idea...do you think that this model fixture is available anywhere else, or is it "discontinued"?
I think the galley light in my trailer is the same as the bunk-lights...it would be good to do that one, too.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-09-2008, 09:54 AM   #550
Well Preserved
1993 21' Sovereign
They are the original lenses, the bright white flourescent tends to whiten the yellow a bit.
Here are the specs for the lights:
MODEL 115
Watts: 15
Lamp: One F15T8/CW
Voltage: 12 VDC
Amps: 1.3
Lumens: 825
Dimensions: 18" x 4" x 1.375"
Dimensions (mm): 457.2 x 101.6 x 34.9
Weight (kg): 1.04 lb (0.472 kg)
Thinlite still shows them "available".
Install was almost pathetically easy, simply remove the old cover, remove the cover from the thinlite, bend the housing a bit so it will fit the OEM fixture, hack off the rivets holding the sockets, rivet the thinlite in place, snap the original lens back on.
Total time to install was 20 minutes for both.
Old 06-09-2008, 10:57 AM   #551
Well Preserved
1993 21' Sovereign
Another repair
Something that's been bugging me ever since we got Bertha is one of the shower door panels is broken. It was held together by some duct tape when we started, I removed that and glued the pieces together so it looked a little better, and it didn't leak, but you could really tell it was broken. I've been on the lookout for a new door since day one, and found one on Ebay thanks to a heads-up from another forums member (thanks, ganglin), but was outbid.
So, I made a trek to Ace Hardware this morning, and picked up a 16"x48" piece of clear plexiglass. I also got a spray can of "Krylon instant frost window frosting" to make the plexiglass more opaque. I drilled out the rivets holding the frame together, removed the broken pieces of amber plexiglass, and installed the clear (now white frosted) plexi in its place. I had been planning to replace the fresh piece with an amber look-a-like when I found one, but it turned out so well I think I'll replace the amber piece with this stuff, unless I find another amber piece before I'm ready to tackle it.
Here are some photos of the door taken apart, and put back together with the new piece:
Name:	shower door 001.JPG
ID:	62085   Click image for larger version
Name:	shower door 002.JPG
Name:	shower door 003.JPG
ID:	62087   Click image for larger version
Name:	shower door 004.JPG
Name:	shower door 005.JPG
ID:	62089   Click image for larger version
Name:	shower door 006.JPG
Old 06-09-2008, 05:21 PM   #552
sd90mac's Avatar
Hi,
I asked Terry to go back to Ace and get another piece of plexiglass and replace the other shower door. It really looks nice with both pieces replaced.
Marie
When people lie to you, and refuse to honor their word, don't regret trying to follow a dream, new adventures and friends await you.
sd90mac is offline   Reply With Quote
Old 06-09-2008, 07:58 PM   #553
Phil/Edee's Avatar
1999 25' Excella
Bemidji , Minnesota
^_^
Uh... Terry... about the under sink restoration with the new FloJet... can you clean up all that "nest" of tubing while you're under there????
Ha.... Hey, we won't recognize the place when we get down there next year!! Good work....
Hugs to all...
P & E
“Cats and dogs are magical creatures... just petting one can make both of you live longer!"
Phil/Edee is offline   Reply With Quote
Old 06-09-2008, 08:08 PM   #554
Well Preserved
1993 21' Sovereign
Hugs to all...
P & E
It's an "instant clean up", just slide the door shut.
Old 06-10-2008, 10:13 AM   #555
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Very nice install - looks bright and clean!
Pat
pmclemore is offline   Reply With Quote
Old 06-10-2008, 10:38 AM   #556
Well Preserved
1993 21' Sovereign
Pat
It makes it much brighter inside the shower area as well. If anyone has the old amber shower door inserts, I would recommend replacing them with the white frosted ones, it makes a lot of difference in there. It also brightens the bathroom as well, without that dark orange stuff. All it takes is drilling out the two top rivets on the sides of the channels, lifting the top channel out, lifting the inserts out, installing the gasket around the inserts, and reinstalling everything.
Old 06-10-2008, 06:13 PM   #557
Well Preserved
1993 21' Sovereign
Fantastic-ally successful
When I left for work this morning, I turned off the a/c, and opened the vents in the front and rear of Bertha, and set the Fantastic on "auto". I took a trip back here during my lunch break, and found the vent open, and the fan fanning like it was supposed to. We also had a small amount of rain later in the day, and when Marie got home, the fan had closed on the rain, and re-opened when it stopped. So, I will call this upgrade a success.
Now, as for the shower door inserts, it is important to note that the doors are different widths, one is an inch narrower than the other one. Silly me, I didn't measure door #2, and just got a second sheet of plexiglass in the same dimensions as door #1. I then found out to my chagrin they are not the same width. I then scribed a line down the length of the insert, and attempted to make a clean break along the line. Umm, my attempt was less than perfect, I wound up snapping a corner off the insert, so off to Ace Hardware I will go this coming weekend...
Old 06-24-2008, 06:32 PM   #558
Well Preserved
1993 21' Sovereign
Just so you know, we haven't run out of things to to with (and to) Bertha, but I have been busy with a few other projects, some of which indirectly involve our trailer.
First, I got the narrower (14 1/4" wide) shower door insert, frosted it, and installed it. It looks a lot better than the 1970's brownish-orange insert, and matches the insert I just installed to replace the broken one. If anyone else has one of these black-tank-contents-colored shower doors, I would recommend changing the inserts for white ones. It does make a world of difference as far as being brighter, both inside the shower and out.
Second, I removed one of the horizontal tambours in the bathroom, and cleaned the tracks and reinstalled it. Now it opens fully, without risking tearing the cabinet off the wall when trying to open it.
Third, in one of my "measure once, cut twice" moments, I removed the twist latch for the old nylon strap that secured the shower doors for travel that rotted to dust long before we got our trailer. I then installed a swag hook for an elastic strap on the outer edge of the shower door, and drilled a hole for the second one on the other end of the door. I was careful in that area, because I was drilling into the closet, and there were some wires, as well as the vent pipe for the grey tank there. I drilled through the wall, stopped, looked inside the closet for the hole. Nothing. Must not have drilled all the way through. I stuck the drill bit into the hole, and felt something else in the hole. I shined a flashlight into the hole, but couldn't see anything but black. I then grabbed my trusty cordless drill, and drilled some more. The drill went through whatever was in the way, and I went back to check on the hole. Still nothing. I've bottomed the drill out, so there has to be a hole there. All it is is a single 1/4" piece of wood.
I grabbed the flashlight again, and looked very carefully. I found the hole, all right--behind the vent pipe! I had drilled a hole in the vent pipe. Sigh...
I patched the pipe, and exercised the better part of valor with that project for a while.
Another thing that fell into my lap during the weekend, is a slightly used Hensley Arrow Hitch. While I wasn't looking for one, the price was right. I just had to remove the bent/broken/torched off parts so I can get the rest of it, and install the thing on Bertha. I got very little info on the circumstances of my acquisition, other than it came off a 34' Excella that flipped, totalling the trailer and tow vehicle, and none of the occupants made it through the accident alive. I'm hoping to have the HaHa installed in time for our next trip.
I'm anxiously awaiting the delivery of a pair of LED tail light bulbs, and will post pictures of the install when they arrive. I ordered the 90 degree angle white 1157 replacements so they can fit directly into the lights we have there now.
I'm also waiting for a fresh water tank to get here so I can experience the joy of crawling around in the mud under our trailer, trying to put it in by myself...
Old 06-24-2008, 08:07 PM   #559
richinny's Avatar
2011 34' Classic
terry, are you going to have the hitch magnafluxed?
Ricky
Old 06-24-2008, 08:50 PM   #560
Well Preserved
1993 21' Sovereign
It's not a bad idea, especially considering the circumstances surrounding its sojourn to the back of my truck. I'll see if I can find someone willing to do this.
1974 sovereign, travel
The adventure begins.... in more ways than one! katzklaw 1960 - 1964 Overlander 157 12-21-2014 03:54 AM
Our full time adventure begins on Monday! zombyw00f Full-Timing 18 12-13-2007 09:38 PM
"The Tube's" Adventure Begins myboyburt Cleaning, Stripping & Polishing 44 07-11-2006 02:50 PM
Off to LA....The Adventure begins JodynJeep On The Road... 29 11-20-2003 12:23 PM
albert's excellent adventure john hd Our Community 13 08-06-2003 07:58 PM
