Old 11-14-2014, 12:56 PM   #1
1977 31' Sovereign
Seneca , South Carolina
Tank removal for permanent placement
I am a new member and a new owner of my first AS, a 1977 Sovereign. I am remodeling the trailer to make it my permanent guest cottage. I will be connecting to my septic tank, water, and power. I am wondering about the logic of removing the holding tanks and running the water and sewer directly out. I have seen a thread about how to remove the black water tank but I would love some advice on what I should do.
TomWoodson53 is offline   Reply With Quote
Old 11-14-2014, 02:07 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would not remove the tanks. The gray one you could just leave the valve open. The black tank I would suggest leaving the valve closed and opening it as needed, witch will not be that often.
You greatly reduce the value of the trailer if you were ever to want to sell it with the tanks removed. I see no advantage to removing them.
Permanency may trigger a tax liability depending on your location.
2004 Excursion 4x4
Permanent A/C removal. CorySessums Furnaces, Heaters, Fireplaces & Air Conditioning 10 08-27-2015 10:34 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Permanent Placement of a Trailer??? crabbey1 Full-Timing 8 02-23-2014 06:11 AM
'65 Overlander dimensions/placement fresh water tank Hihosilver2 1965 Overlander 4 06-04-2010 06:52 AM
Permanent home? DGR160 Our Community 12 04-23-2003 10:49 AM
