Old 04-28-2013, 07:57 PM   #1
Airstream fanatic
Grapes's Avatar
Bouse , Arizona
staying cool???
How do you stay cool in your Airstream?!!!
Its like 102 degrees already and my electric bill is slowly climbing... can anyone make any suggestions for staying cool, without running the AC all day??
I've tried opening the windows at 5am to let the cold in...and right around 8 when it starts to get hot, I buckle everything down. But my problem is by noon, I'm roasting and I have to turn the AC on... and it runs until 6:30-7pm at night....
Help anyone would be greatly appreciated!!!!
Cass
1979 Sovereign International (Olivia)
1986 F-250 4X4 (Oscar)
BLOG: http://grapesbigadventure.wordpress.com.
Grapes is offline   Reply With Quote
Old 04-28-2013, 08:08 PM   #2
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Head North or find covered parking.
Airstreams are not well insulated. Perhaps you can get a Whispercool portable swamp cooler.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 04-28-2013, 08:43 PM   #3
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
We have a 31' Excella and we set the thermostat at 74 degrees and put a small fan in the bedroom on medium and one on the galley counter, also on medium.
I would not shut my A/C off. I takes too much energy to try to cool everything down again.
Someone [posted on here that an Airstream looses almost 1200 Btu's through the aluminum.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-29-2013, 01:27 AM   #4
2005 19' Safari
GLENDALE , AZ
Note: For those unfamiliar with Arizona, Bouse is near the portion of the Colorado River commonly referred to as "the Parker Strip" (i.e., the strip of the Colorado River, near Parker, AZ, that divides Arizona and California). The summer daytime temperatures in this region often reach 115-120 degrees F.
Grapes, if you are a snowbird and/or haven't been through your first Arizona summer, now is the time many head for the mountains. Otherwise, be prepared for temperatures close to those in Death Valley, accompanied by humongous electric bills.
If you want to stay in Arizona, your best bet is to head for Prescott, Flagstaff or the Arizona White Mountains (Payson, Show Low, etc.), preferably where the altitude is above 5,000 feet. It is still near freezing at night in some of these areas, but the overnight lows will warm up quickly in the next few weeks.
Otherwise, you might want to get your map out and start looking at the Rockies or Sierra Nevadas. Many campgrounds in higher elevations that were closed all winter will be open soon, if they aren't already.
Old 04-29-2013, 06:18 AM   #5
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
I have heard painting your roof with a special white coating will help reflect heat. Consider cutting out pieces of Reflectix for each window. Best idea is to move near me in northern Vermont. Our houses don't even have airconditioners!
http://1960airstreamtradewind.blogspot.com
Love. You can learn all the math in the 'verse... but you take a boat in the air that you don't love... she'll shake you off just as sure as the turn of the worlds.
2vets is offline   Reply With Quote
Old 04-29-2013, 06:34 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Airstreams aren't going to stay cool at 102* without running the AC, even parked in the shade. If you are parked in direct sunlight Fahgettaboudit!
Here in the Deep South, humidity is the killer. We run the AC 24/7 on some trips. Others we luck up and the temps cool enough or a cold front comes through and drops the relative humidity to below 50% making it pretty nice.
Aaron
WBCCI #XXXX AIR #2495
Old 04-29-2013, 06:46 AM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Full sun exposure in an Airstream in those temps requires AC...no other way. Next best way to reduce electrical use is to get it under some shade. Makes a big difference. That shiny aluminum skin just soaks up the heat. I remember my first trip out with my then new 2001 28' Safari. Next to me was a friend who had bought my 30' SOB. Both trailers had 13.5 K air conditioners. We were in full son 104 degrees. My Safari was 88 inside, my old SOB was 78. The SOB was white in color.
Once the sun was out of the sky, the temperatures inside got back to normal. Hence my comment regarding shade....also the reason that I took the option back in 2004 to build our Classic with a 15K AC unit.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-29-2013, 06:51 AM   #8
SteveH's Avatar
Common Sense , Texas
Where you are, Bouse , Arizona, you are not going to stay cool in the summer, even with the air conditioner running all the time.
Regards,
Steve
Old 04-29-2013, 07:01 AM   #9
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
It wouldn't take much to convince me that it was a 12,000 Btu loss on some of those hot summer days we see in Texas also. The best defense is a couple of strategically place shade trees and they are mighty scarce.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 04-29-2013, 11:24 PM   #10
Airstream fanatic
Grapes's Avatar
Bouse , Arizona
The PO painted the top of the trailer already. And I've tried the reflectix material. Ugh... Vermont is far lol
Cass
