11-28-2011, 10:57 AM
#41
Master of Universe
2008 25' Safari FB SE
Grand Junction
When I first started backpacking, Jack Daniels seemed necessary. You don't even need a glass. There's always a simpler alternative when mood altering is required.
Gene
11-28-2011, 11:03 AM
#42
1977 Argosy Minuet 6.0 Metre
Colorado Springs
Originally Posted by zlee
... I'm trying to keep things as small and light as I can, as there's just not a whole lot of room in a 19' Bambi, but I'm too spoilt rotten to do without my morning espresso....
We really like the Aero press: AeroPress® | AEROBIE® High Performance Sport Toys
Easy to use and make great coffee if you start with the good stuff that is.
Royce (K0RKK) 146.460 simplex
Web page https://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
11-28-2011, 11:54 AM
#43
2008 19' Safari SE
Denver
Yes, but Gene, JD puts me to sleep...
Royce, that is COOL. I'm getting that instead of the collapsible filter - even though you have to use a paper filter, I think it'll be worth the hassle...
"If you can't be a good example, then you'll just have to be a horrible warning." - Catherine Aird
Blog: 300 Miles or 3:00
11-28-2011, 11:12 PM
#44
2008 19' Safari SE
Denver
All right, one MORE question for you smart people.
My sister is giving the Bambino, as she insists on calling it, a thermal cooker. Yippeee! I'm so excited! But here's the thing - when you use a thermal cooker, you have to make sure that everything in the inside pot is at boiling temp. So it may have to boil for 10-20 minutes or so, depending on the thickness of whatever's in it. Does it make sense to use the propane for that even when I'm plugged in, or is it worth the expense to get one of those portable induction thingies for when I've got electricity? I don't know how much propane it takes to simmer something for 20 minutes!
Anyway, if it makes sense to buy the induction thingy, let me know, I want to buy it while it's on sale. (It's five pounds, too, so it has to be worth it...)
11-28-2011, 11:30 PM
#45
1959 17' Pacer
Long Beach
Let's see, I can do a quick estimate and someone smart can refine it...
It takes 1180 Btu to bring a gallon of water to boil (from 70F to 212F), let's say you bring it to boil in 15 minutes, and then keep it there for 15 minutes. After you've reached boil, you are essentially adding enough heat to maintain the boil and slowly evaporate off some liquid, so your stove burner efficiency becomes much more important. To be safe let's call it 1000 Btu/hr. So that means you would use 1180 + 1000/4 = 1430 Btu. But wait, overall stove efficiency is probably like 60% depending upon your burner, pot, etc. So really you would use 2380 Btu.
Propane apparently has a value of 21600 BTU/ lb according to the interwebs, so you would use 0.11 lbs of propane.
Somebody please check my back of the envelope calc.
11-29-2011, 12:44 AM
#46
2008 19' Safari SE
Denver
Sooooo, in a year or so, am I going to look back at these answers and go, "pfffft, I should have known that!"?!?
11-29-2011, 05:04 AM
#47
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Is it just me??
POI....I have never run out of LPG while camping. One goes empty, get it filled.
Now on the pad that's another story......
"You don't know where you've been until you leave, enjoy life" RLC
11-29-2011, 05:40 AM
#48
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Can't beat a cup of perked coffee!
11-29-2011, 09:44 AM
#49
Master of Universe
Grand Junction
We haven't either, after the first time. I have no idea what this has to do with the original question.
Gene
11-29-2011, 10:56 AM
#50
2008 19' Safari SE
Denver
I guess what I'm asking is, from what everyone said originally, it seems propane is more efficient to use than electricity. So if I'm using a thermal cooker, if it's that much more efficient to use propane, should I continue to use propane even while plugged in, or is it worth purchasing and carrying a five pound $80-$100 induction thingy to use while plugged in, given that I currently expect to be plugged in about 50% of the time and that I'm in a 19' Bambi and want to save on weight and space? Am I going to run out of propane in a week if I do so, if I'm using the thermal cooker every day? Two weeks? How long is my propane "supposed" to hold out, on an average?
Or is this really a stupid question?
11-29-2011, 01:46 PM
#51
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Shopping: Electric vs. Propane
Greetings zlee!
Your question is quite reasonable, but crafting an answer is quite difficult as there are a huge number of variables involved in one's use of propane in an RV. Some of the variables include: - How much camping is being done where the propane funace will be utilized. In cold weather with the furnace in constant operation, a 20 pound tank may only last three to five days.
- How much hot water is required by the occupants of the coach, and whether the water heater is allowed to remain lighted continuously.
- How much if any baking is done in the coach's oven (if so equipped). The oven tends to be a heavy user of propane and if used frequently can help to quickly deplete a 20-pound tank.
- Usage by the refrigerator. Typically this only becomes a concern when boondocking or at minimum electric rallys where the refrigerator must be run on propane. The refrigerator isn't a huge consumer of propane, but needs to be factored in when boondocking.
When I was camping in my Overlander for six weeks each summer, two 40-pound propane tanks would take me through the entire season. My season may have not been typical as the following would impact my propane use: - When camped, my water heater pilot is one of the first things that I light and among the last items to be extinguished prior to departure. I am not fond of gas appliances so do not like to repeatedly re-light pilots during a stay.
- Three of those six weeks would typically be spent in limited-electric rallys where my refrigerator would be operating on propane continuously. My coach has a 3-way Dometic so it operates on 12-volt DC when traveling.
- One of those six weeks would typically be spent in a mountain location where the furnace would be operated for eight hours per day which generally accounted for the majority of my propane usage.
- My typical average while camping is one meal per day cooked in the coach utilizing the propane range. In most cases, I use three burners when cooking a meal for about 20 to 30 minutes.
My last trip of this nature, resulted in a use of approximately 80% of the propane in my two 40-pound tanks.
I know that this doesn't provide a definitive and direct answer to your question; but with the variables involved the best answer may be a little experimentation and tracking of usage levels once you start camping in your coach.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
11-29-2011, 01:47 PM
#52
1995 30' Excella
Bowie
, Maryland
I can tell you this... we bought our trailer in June, with 30 lb bottles. Both were empty at the time, and I had them filled. We camped on weekends in June, July (week plus trip here), August, September, and October, using the furnace some in September, and pretty much continuously during the weekend in October, plus testing the furnace and the water heater both for a couple hours at home. Our trips include cooking on the stove, two of us showering, and of course doing dishes once or twice a day. Some of those were three day weekends, too.
After all that, at this point, the first bottle is just about empty. We haven't touched the second one yet.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
11-29-2011, 02:03 PM
#53
2008 19' Safari SE
Denver
Yeah, thanks, Kevin, I did sort of know this was at the very least a "how long is a piece of string" question.
K, given Skater's anecdotes, and Peter's calcs, I think I'm going to NOT get the induction thingy for now and save myself five pounds and some storage room. I can always get it later, if I decide I'm using too much propane, right? and given developments that are developing even as we speak, I may be spending more time boondocking than I'd planned on, sooooo...
You guys rock.
11-29-2011, 03:36 PM
#54
2007 25' International CCD FB
Holladay
, Utah
You guys rock.
Get a solar panel, fill your propane tanks when ever you can, and then don't worry about energy again. Electric and propane are not going to be your limiting factors when boondocking, it is going to be your gray and black water tanks. You can always get in your tv and drive to civilization for fresh water, food and even propane when necessary. But handling the gray and black water is the real challenge. I do not have a portable system, when necessary (no more than 8 days) I hook up the AS and take it to a dump station. I know there are portable systems that allow you to carry out the waste in your tv, but I know nothing about them.
If you are going to be boondocking you need to address this, either plan on taking the trailer to the dump station, or research the portable solutions. As for your original question, use propane as much as possible, especially for heating food and people, and your solar electric for everything else. Your propane tanks will last you a long time.
11-29-2011, 05:05 PM
#55
2008 19' Safari SE
Denver
Can I fit a big enough solar panel on a 19' Bambi to do that, though? I think I might be able to fit a 80w panel...would a portable one (or two) be better instead of something on the roof? Does the solar keep up with having to power a computer and a laptop? This is all stuff I thought I could deal with NEXT week...
Yeah, I'm planning on dumping whenever I need it. That's a whole 'nother subject...can you use the Flush King or is the Sewer Solution better? Rhetorical questions here, but not for another thread...
Well, maybe "boondocking" isn't the right word. What's the word for living in your TT completely self-sufficiently whether in the city, the suburbs, or a forest or beach somewhere?
11-29-2011, 05:22 PM
#56
Master of Universe
Grand Junction
Like others, we use very little propane until fall comes (or spring). The furnace uses a lot of propane (and battery too) and may only last days when the temps go down into the 20's at night and 40's during the day. Since you have a smaller trailer, you will get more out of it. When we have electricity, we use a ceramic heater (they are cheap—check Amazon) and use the furnace less until the temps get into the lower 30's and we need to heat the water tanks. You can put Reflectix on some windows, skylight and fans and cut down on heat loss (or cooling loss in the summer)
The word amongst the RV world is "boondocking" when you don't have hookups. Your ability with a Bambi to boondock will be limited because of the smaller tanks, half the size of a 25' and even less if you have a 16' Bambi. They really aren't made to camp more than a few days without hookups, though by being very careful you could go longer especially if you have a blue boy.
We use the Flush King. It makes backflushing easier and works well. If you are squeamish about bodily fluids and solids, the sewer solution may be better for you.
Solar panels are getting smaller and cheaper. The ones mounted on the roof have more watts per square foot than the ones that fold up and you put out when camped. There are plenty of threads about solar, sewer stuff and even one on whether "boondocking" is the best word. Lewster is the Forum resident solar expert and you could contact him for info.
Gene
11-29-2011, 05:51 PM
#57
2008 19' Safari SE
Denver
Bless you, Fadder. How's weather out in Crawford? Denver's okay so long as the sun is out and then it's COLD.
Yeah, I'm getting terminally confused with the solar thing.
11-29-2011, 05:57 PM
#58
2008 19' Safari SE
Denver
P.S. I'm not, especially. The one that takes up the least amount of space wins.
11-29-2011, 07:34 PM
#59
Master of Universe
Grand Junction
Crawford weather: Cool, then cold, then cool…. Not much precipitation and lots of sun. Tomorrow will be a good day to cut up a big, old piñon tree the beetles got.
Flush King doesn't take much space, but the sewer hoses do.
Gene
11-29-2011, 07:38 PM
#60
2008 19' Safari SE
Denver
It seems like they all do, really, but if I can avoid handling the stinky slinky, that'd be a plus. Do I really need two 25' hoses to deal with it?
