Old 10-24-2010, 05:33 AM   #15
Zigidachs's Avatar
2011 30' Classic
Ridgefield , Washington
We pay an extra $5/mo for our Direct TV receiver which calls our RV home. Many take their receiver from home and use it in the RV, a service for which they are paying whether at home or on the road.
We have the roof mounted Trav'ler 3005 and really have not had any problem accessing a signal.
I have read that the Vu-Cube is compatible with the Dish HD signal but not the Direct HD signal because it does not lock on to both the Ku and Ka bands.
The same with the King Dome. Also I have read that the domes lose about 10% of signal strength b/c of the cover, does not receive Direct Ku/Ka bands, and requires periodic treatment with cleansers to prevent rain from adhering and diminishing the signal.
Zigidachs is offline   Reply With Quote
Old 10-24-2010, 05:51 AM   #16
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
One option for you that may be worth looking in to www.motosat.com we love our setup even though, at times, trees block the reception. Even with that we don't miss having to do the outdoor setup thing, especially in bad weather. So many options are available it's sometimes difficult to choose. Good luck in finding one that suits your situation and budget.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 10-24-2010, 05:51 AM   #17
Denis4x4's Avatar
Durango , Colorado
I've had a King Dome for four years and have had no problems in rain diminishing the signal. I'm using a Dish Network box that is usually mounted in my shop when I'm on the road.
Denis4x4 is offline   Reply With Quote
Old 10-24-2010, 05:55 PM   #18
2000 34' Limited S/O
Jamestown , North Carolina
Agree! I pay $5 for the receiver in my AS which is on my DirecTV account. If I was trying to bypass paying for the service, I wouldn't recommend it to others.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 10-24-2010, 07:17 PM   #19
Zigidachs's Avatar
2011 30' Classic
Motostat has a slimline dish compatible with Direct TV HD which weighs only 39.5#!!!!! The Trav'ler weighs 54!!!! That might represent a significant difference on the roof of an AS. Thank you for the tip! This site is terrific: great experience and advice.
Old 10-30-2010, 04:57 PM   #20
2001 19' Bambi
Ashland , Oregon
Wow, a wealth of information to consider. Many thanks.
Camping World has a promotion going for the Winegard Dome which gets rave reviews. It costs $800. Yikes. Isn't there a cheaper way to do this?
Kathleenh is offline   Reply With Quote
Old 10-30-2010, 05:46 PM   #21
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
We have a Direct TV account at home and when we switched to HD we kept the old dish and mount it on a Winguard portable tripod. The old receiver costs $5.00 per month extra on our home account. I have 100' of cable that allows me to move around most trees etc. It only takes 5 minutes to set up. I set the TV to signal beep and go outside and move dish until the beeb is really chirping. This works 99% of the time.....Tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 10-30-2010, 10:01 PM   #22
How about the actual wire connections? I have a 2005 CCD international, 25ft. Just subscribed to direct TV with two receivers. The install techs had an extra dish they gave me.
Does the AS typically have an in line amplifier that I need to bypass for the sat signal to work? Thanks in advance
goldwing70 is offline   Reply With Quote
Old 10-31-2010, 05:26 AM   #23
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
I have a 2005 Bambi, so it may be a bit different. There is an in-line amplifier, but I believe it is only for the roof top antenna. Mine has two separate connections, one for the roof top antenna with the signal amplifier (green LED light). The other is for the satellite/cable connection, and is labeled CABLE/SAT IN, and CABLE/SAT OUT. After I connect my DirecTV dish to the outside box, I connect a short cable from the CABLE/SAT IN jack to the satellite receiver. I leave both the roof top antenna, and the satellite dish connected at all times, and switch back and forth via the input switch on the TV. I don't recall having to bypass the amp.
Hope that makes sense. It's early here.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 10-31-2010, 06:01 AM   #24
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
I managed to get this picture without waking the wife (we're at a state park campground in Delaware). The top faceplate shows the connection for the roof top antenna. The lower one shows the black cable (CABLE/SAT IN)that connects to the television. The gray cable on the bottom is a short jumper that isn't connected to anything.
2005 Bambi
1968 Trade Wind
WDCU
Old 10-31-2010, 11:49 PM   #25
Thanks Silver! Pics are great. I have similar panels in my unit. I'll try that and see what happens.
Old 11-06-2010, 06:36 PM   #26
HandyHank
2001 30' Excella
Bastrop , Louisiana
Dear Adage
I just recently (as of last Monday, 11/1/10) became an official full-time. I called DirectTV and they moved my receiver from house to 30' Excella. The installer was supposed to bring a tripod but never got the message. I called the 'movers' of Direct back yesterday and although I'm 500 mi farther west, they are coming here on Wed specifically to bring a tripod to fit the 2" post tripod to my Slimline DirectTV dish. I also have a 'swimmer' LNB which replaces 2 or 4 of the old LNB's. Apparently most dish antenna have a 1-5/8" post except the Slimline. Most tripods are also that size so if you have the new Slimline check to make sure about the post size. I'll let you know how this works out. BTW I have to pay for the new 2" post tripod. There was no mention of this being illegal or somehow stealing.
HandyHank is offline   Reply With Quote
Using Satellite tv ALANSD Electrical - Systems, Generators, Batteries & Solar 46 04-22-2006 08:22 PM
New satellite! 65 overlander Electrical - Systems, Generators, Batteries & Solar 7 02-14-2006 07:01 PM
Satellite TV help Nick Danger Electrical - Systems, Generators, Batteries & Solar 11 01-07-2005 11:55 AM
satellite sparkleplenty Electrical - Systems, Generators, Batteries & Solar 2 09-30-2004 09:37 PM
Satellite ALANSD Electrical - Systems, Generators, Batteries & Solar 9 08-19-2003 12:36 PM
