Old 10-06-2014, 10:42 AM   #15
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I do not full time but on occasion we use our AS in the Summer, when we have guests or I am doing a project of sorts inside. The only issue I ran into was condensation on the metal parts of the AC when we frequently opened and closed the door with the high humidity. Other then that,good to go!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 10-06-2014, 02:58 PM   #16
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by Zil View Post
When I had my unit, I ran AC while in Fla. AC failed and the tech said because of low voltage from the outlet. I had checked things when first settled in but not later.
A TT here caught fire when owner left town with both on low. Low park voltage and high early morning humidity placed too high an amperage load for voltage available. Leave fan on high in this instance. Even with dehumidifier running constantly A/C fan should always run on high well before dawn. An auto former may help but one is near TT elec system limits.
Old 10-06-2014, 03:08 PM   #17
1981 31' Excella II
New Market , Alabama
I would not run the thing full time in storage. I would consider a dehumidifier. I keep a box fan in front of a window with it on low. A couple other windows are open to circulate air. If the inner skin is cold water will condense inside the walls. If the inner and outer skins are more or less the same temp then less condensation. Keep it out of the sun as much as you can but let it sit in the sun some to dry things out. Did you get a roof over your pad yet?
Perry
Originally Posted by PharmGeek View Post
I am interested in this general question as it relates to storing my Airstream here in central alabama...have heard folks leave it on in summer all summer set at say 85 degrees...I could later on have 50 amp hookup at home...I do not now...for now I have enough juice to run dehumidier only full time - keeps it hot but dry year round (keep at 50% in summer).
If I LIVED in it in FL.....that sucker would simply run as it needed to all the time
Old 10-06-2014, 03:36 PM   #18
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I now use dehumidifier full time and keep things sealed up
No roof yet - next year projected
PharmGeek is offline   Reply With Quote
Full Time Streamer versus other full time RVs rodsterinfl Full-Timing 31 01-18-2016 05:31 PM
First time living in Airstream full time. MyNancy1977 1977 Excella 500 0 02-23-2015 08:09 AM
First Time and Full Time! JRoss3030 Member Introductions 9 03-20-2010 11:28 PM
Fun time, African Events, Time running out to join in PeeWee Off Topic Forum 1 08-09-2009 09:12 AM
Part Time vs Full Time (Days/Year) InsideOut Community Polls 30 10-23-2005 09:43 AM
