Old 02-20-2009, 02:53 PM   #29
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Originally Posted by cbgenrich View Post
I'm considering purchasing an Airstream for extended trips, basically full-time, just me and my dog. One thing I know about myself - I'm a recliner - and that's not going to change. I'm reclining right now in fact.
I really like the reclining lawn chairs that are available these days. I'm sure I will spend many hours under the awning in one. Kindof my objective, really.
Sometimes the weather or other factors will be problematic - that's why they come with heaters, airconditioners, and window screens I suppose. I'm trying to picture myself reclining in an Airstream.
Here's the thing - I don't see recliners in Airstreams. The only solution I can see is to bring my reclining lawn chair inside at those times. I'm sure some Airstreams have enough open floor space to handle that, SO units for example. I suspect some don't.
How do others meet this need?
-CB-
I don't know how the rest of them handle it, but here's what I did. First I got rid of that god awful thing they call a sofa, and put in two recliners built by Lambright Aluminum Fabricators, in Shipshewana, IN.
I built new storage areas on both sides of the trailer and across the front wall. I do have a fairly good woodworking shop, (this helps).
Pictures below (if I can figure out how to do it).....if you have questions, let me know.
Larry
Name:	Airstream recliner installation 005.jpg
ID:	75782   Click image for larger version
Name:	Airstream recliner installation 004.jpg
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 02-20-2009, 07:35 PM   #30
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Tami & I have been wanting recliners in our MH. part of the generator box is under the couch. This leaves us with 68" of usable space for the recliners. We can't seem to find a comfortable recliner that is 34" wide (outside measurement). We've come up with a plan B if our search fails. A reclining love seat. We'll have to drive the MH to the furniture store to make sure whatever we purchase fits through the door.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 02-20-2009, 10:23 PM   #31
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
3 Dog Nite, the Barcalounger Abbey is 29-1/2" wide. It can be set as close as 3-1/2" from a wall. I've set in this chair and it is surprisingly comfortable. It has good leg support and a clever "pop-up" head rest which deploys when you pull the recliner handle. See: Gordons Fireplace Shop:
So Long!
Bob Thompson is offline   Reply With Quote
Old 02-21-2009, 07:16 AM   #32
hookedonclassic's Avatar
Fond du Lac , Wisconsin
We have the 34' with the L couches. If I were to put in a recliner, I would leave the love seat and corner entertainment stand in across the front and take out the long couch on the side which would give me good room for a recliner. The way it is now works well for us. We each take a couch and put a pillow under our feet on the shorter couch.
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
Old 02-21-2009, 07:19 AM   #33
Just looking at my post above, it could work taking the short couch out instead.
Rich
www.compassion.com
Old 02-21-2009, 08:18 AM   #34
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
I just use a couple of pillows against the wall and lay on one of the two gauchos. I didn't have to remove anything and it cost me nothing (I use the same pillows we use for sleeping) True, I actually have to pick my legs up rather than having that recliner pick them up for me, but I can really use that exercise.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 02-21-2009, 10:43 AM   #35
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I have been known to bring my walmart lafuma knock-off recliner in on cold evenings and read in it. Its a low tech solution, but it works well enough.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-25-2009, 07:27 AM   #36
Cstar's Avatar
2006 28' Safari SE
Columbus , Ohio
Images: 20
We have a 06 28' Safari SE and are in the process of adding two Ekorne recliners to the floor plan. We had the factory remove the dinette and cover the exposed wheel well with the same laminate used for the walls. We found a local furniture store that was closing out their stock of Ekorne chairs and picked up two leather models that by measurements will fit. Still a little skeptical it won't be a crowded but I know it will be more comfortable. The dinette is fine for meals but was wasted space for us otherwise.
Right now the chairs are in our living room at home. They are definitely comfortable and I can't wait to get them in the Airstream and try them out. We will be on the road for a few extended trips this summer and expect the "new" setup to be just what we wanted. I will post photos to this thread this spring when we get everything set up.
Corky
Cstar is offline   Reply With Quote
Old 03-13-2009, 09:57 PM   #37
Cstar's Avatar
2006 28' Safari SE
Columbus , Ohio
Images: 20
This spring came sooner than expected. Made a quick run to LA and TX and decided to take the recliners. Here is the temporary set up. Seems to work well, so far. We do have to move one of them for TV viewing but they are very comfortable and much better than the dinette.
Name:	March 09 185.jpg
Old 03-14-2009, 07:05 AM   #38
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
-CB-
Take the time to check out page three of this thread, you'll see what I did with our 31 foot AS.....The has proven to be a very comfortable arrangement, and I more than doubled the amount of storage as well
Larry
Airstream - A Case Study in Entrepreneurship... From the Inside Out Roamin Cat Airstream "In the News" 2 02-21-2009 09:41 PM
Motorcycle inside Airstream? Foureagles Towing, Tow Vehicles & Hitches 25 01-08-2008 03:19 PM
No Electric Inside Airstream LetsRollAZ Electrical - Systems, Generators, Batteries & Solar 12 12-26-2007 08:59 AM
Using an Airstream inside a restaurant SilverCottage On The Road... 9 06-04-2007 09:36 PM
Reclining Leather Seats Donald B Graves Airstream Motorhome Forums 0 02-05-2003 06:38 PM
