Old 11-14-2015, 02:38 PM   #1
ILOVESALLY's Avatar
2007 25' Safari SS SE
Sarasota , Florida
Problem after flushing tank.
I regularly flush my black tank and this time after flushing my black tank it doesn't empty. It's not blocked from the toilet end and seems clear at the road side end. We never put paper down or poop in it so I'm wondering did I trigger a shut off a valve or something that I don't know about.
No previous problems doing this?
LoveSally
ILOVESALLY is offline   Reply With Quote
Old 11-14-2015, 02:44 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Maybe there is nothing in the tank to drain, especially if you never used it...
Old 11-14-2015, 03:02 PM   #3
ILOVESALLY's Avatar
Sarasota , Florida
Ha ha, the bowl is full and not draining. We defiantly use it, full timing for a year😏
LoveSally
Old 11-14-2015, 03:32 PM   #4
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Sounds like a blockage, possibly some part of the tank or internal piping broke loose causing it. Maybe a probe going in through the drain valve might release it enough to drain. If that helps, remember you still have the problem that caused it!
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 11-14-2015, 03:36 PM   #5
Gainesville , Florida
Thought you didn't put paper or poop in it.
Old 11-14-2015, 03:44 PM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
. I don't understand, first you don't use it now you do? If full you must have left the valve open, draining off all liquids, close it and fill with water, maybe go for a short drive the drain again...
Old 11-15-2015, 10:25 AM   #7
HCR
HCR's Avatar
Livingston , Full time traveler
I thought I had heard it all... Pls. post re what you discover as I would hate to have your problem. Good luck!
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 11-15-2015, 10:33 AM   #8
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Broken/disconnected dump valve?
Old 11-15-2015, 10:52 AM   #9
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
Pretty much sounds like Steve has the inside poop on this one...
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
Old 11-15-2015, 11:06 AM   #10
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Gotta be it Steve! You pull the handle, but the handle snapped loose from the actual valve. Here is a very good thread about what happened and how to repair it without getting completely baptised.
Good luck, and if you put Vicks VapoRub under your nose you won't be able to smell the stuff that comes out while you're doing the repair. The Dremel and vice grip idea should prevent major "leakage".
http://www.airforums.com/forums/f444...lve-84229.html
Paula
Old 11-15-2015, 11:09 AM   #11
TAC CA-420
'55 Airlight's Avatar
Santa Monica , California
Images: 104
The PO states she doesn't put solid waste or paper thru the commode into the black water tank. She says she uses it, meaning liquid waste...
Defiantly Dumping,
Michael
"Of the gladdest moments in human life, methinks, is the departure upon a distant journey into unknown lands... A journey, in fact, appeals to Imagination, to Memory, to Hope,—the three sister Graces of our moral being.’
Sir Richard Francis Burton
'55 Airlight is offline   Reply With Quote
Old 11-15-2015, 11:21 AM   #12
W , New England
Paula
This may be the first and only time I've been "right" about anything Airstream, Paula! 😄
Old 11-15-2015, 11:26 AM   #13
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
Paula
Just had to share...
I was staying at the Americamps outside of Richmond this summer when a family in a fifth wheeler with two tank outflow pipes came into the next site. When they were nearly finished setting up, the father approached and hooked up their grey water sewage line and then to move to the blackwater whilst the wife and kids ran away for a few minutes. He took out of storage a "portable gate valve" is what I call it -- walked over to the blackwater cap, uncorked it to a FLOOD of sewage all over himself and within four seconds had his temp gate valve in place. Unphased, he wiped his nose and went inside.
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 11-15-2015, 04:46 PM   #14
Hi Ian - UGH! that's a TERRIBLE story. Why the heck would ANYONE do that. I'd sooner leave the "temporary gate" ON the pipe - even if it hung out the side by a foot - than take the big brown shower!
And I used to think Robin Williams movie "RV" was overblown. We see stuff on the road every day that just is SO gross and ignorant...
Hope you were upwind dear man!
Paula
Black Water flushing - problem with 2006 Classic suzieleigh Waste Systems, Tanks & Totes 9 07-07-2014 04:28 PM
Tank flushing spousal dispute! badkat Airstream Lifestyle 11 07-03-2013 06:55 AM
Flushing ambassador tank pewalker1 Full-Timing, Winter Living & Workamping 1 04-08-2011 12:16 PM
Problem report/Tank Saver Flushing Tool wyhjr 2001 Safari 11 09-21-2003 08:24 AM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
