Old 12-18-2008, 01:06 PM   #29
kidless's Avatar
1964 26' Overlander
Prince George , BC
Send a message via Skype™ to kidless
No, my forced air has not been working. And where I'm staying,, they preferred me not run the propane heater. Gotta work through that issue. Of course, I need a good alternative for when I'm gone. I'll be away a few days over Christmas, and wouldn't want to run propane anyway. Also, couldn't empty all the water lines with the way I'm set up. Growing pains, and learning everything the hard way. The oil filled radiator heater is great for the room, but doesn't help push heat through the water-line areas. I have gotten a hold of one of those milk-house heaters. Just nobody around here calls them that. All joking aside, I did research it right away. It's basically ugly, big, but does a very good job and is reliable. So that's what I'll use while I'm away. I'll also have someone check my pad everyday.
kidless is offline   Reply With Quote
I am or was confused about full timing Frank's Trailer Works Full-Timing 18 12-31-2007 07:21 PM
banking while full-timing rec Full-Timing 11 07-24-2007 10:38 AM
full-timing njoysrvin Full-Timing 5 06-13-2006 09:20 PM
Full Timing abruce Full-Timing 10 01-29-2005 11:29 PM
I'm off full-timing! zduke4x Full-Timing 10 03-08-2004 10:06 AM
