Old 10-28-2013, 09:51 PM   #1
stellar1dan's Avatar
2013 27' FB International
Yelm , Washington
Full timing and batteries
I've been full timing it for about 5 weeks now and read a post about disconnecting batteries and winterizing. If I'm plugged in full time in my 2013 international is there something I should be doing with my batteries to keep them functional? ( ie disconnecting, placing in stow etc)
stellar1dan is offline   Reply With Quote
Old 10-28-2013, 10:39 PM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
Deep cycle batteries need to be maintained at a full charge to ensure their maximum useful life...
That being said, if you are hooked to shore power all the time with the converter/charger 'ON', assuming it's a 3-way or similar unit that will automatically switch to a 'FLOAT' mode (about 13.6 volts) when the batteries become fully charged - you'll be in good shape...
We have an older AS, and I'm not up to speed on the late model's battery disconnect switch system - your manual should explain the various settings - IE: I'm not sure if the batteries continue to charge when in the OFF position and still hooked to shore pawer...
I don't know if the late model AS's converter/charges have the FLOAT mode capability - check your manual for that info, etc... If it doesn't have a FLOAT mode, it will overcharge the batteries, evaporating the fluid and ruin the batteries - in any event, you should check the battery fluid level every month or so if you are always plugged into AC service...
Happy Trails...
Ray & Pat; Morada, CA
Old 10-28-2013, 11:05 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If I had to guess. The converter in your coach is the least expensive converter that a buyer at A$ could find.
You should get the brand name and model number and do some research on the capability of that converter.
Old 10-28-2013, 11:40 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
When plugged into external power, place the battery disconnect switch by the door in the "store" position. That disconnects them from the converter. Just remember to switch it back to "use" when removing external power, or you will have no dc power to the trailer (the refrigerator will not work even on propane, for example).
You will still need a source to charge the batteries. If you have solar power, that will keep them up perfectly. Or when driving the truck will charge them. Or allow the converter to charge them for short periods.
Doug and Cheryl
Old 10-29-2013, 05:20 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Full timing.....I would get rid of the cheep-o Parallax Converter and upgrade to one that will do the battery charge/maint thing much more reliably.
This has worked very well for us..
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 10-29-2013, 05:40 AM   #6
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
When the trailer is connected to shore power, the converter supplies 12 volt DC power to both run the 12 volt items in the trailer and a charging current to the batteries.
The problem, as mentioned above, is the current supplied to charge the battery is not regulated very well by the less expensive stock converter.
This can lead to overcharging of the batteries and cause them to boil dry and ruin.
This issue can be manage several different ways:
Some folks choose to replace the factory installed converter with one of several on the market that do have better battery charging circuitry.
Some simply "manually" manage the situation by using the the battery disconnect switch.
This is the switch in the trailer that says "STORE" and "USE". Simply place the switch in the store position most of the time. This will disconnect the batteries from the converter and thus prevents the over charge.
But, remember to place the switch in "use" for 6-8 hours once a week to keep them charged. And, again place the switch in "use" when you have to unplug to move or travel.
The red led will stay lit in the "store" position when the trailer is plugged into shore power.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 12-14-2013, 08:01 AM   #7
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
JD
Thanks Jeff, for the confirmation about that constant "glowing" pilot light as the disconnect switch operation is a "little" ambiguous (as is my learning curve). Wish AS would replace that with a regular toggle switch or a separate pilots for shore and battery.
Figure when the Paralax eventually craps out (seems to be a when, not an if), a 3-stage or 4-stage replacement makes sense. Managing manually until then is the plan and a marine wired-in disconnect seemed the best option. While the manual actually does cover the proper battery disconnect routine to avoid overcharging (who knew reading the manual would be helpful?), that rocker switch and constant glowing red light kinda fed my insecurities as I'm just a month into post-sticks & bricks FT vagabondery and first shakedown trip ended with $200 worth of new batteries to maintain more than overnight power.
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
