Go Back   Airstream Forums > Airstream Community Forums > Full-Timing, Winter Living & Workamping > Full-Timing
Old 06-24-2016, 10:06 PM   #1
1976 25' Tradewind
Grand Prairie , Texas
Full timing and Air Conditioning
I am fairly new to full timing and need some guidance on air conditioning . I reside in 1989 25ft Excella in Texas and it is HOT!!! My first question is which unit is best for the Texas heat? I put in a Coleman 1500 last year. Second, do you run your AC on high cool 24/7? I have been turning it off during the day while I'm at work, but it is too darn Hot when I get home in the late afternoon . Is the only way to stay cool to install a 2nd unit; and is that even possible? I thank you for your advice.
txlogic is offline   Reply With Quote
Old 07-01-2016, 09:56 AM   #2
Floatingair's Avatar
1994 30' Excella
Kiefer , Oklahoma
I have already pulled out my solar sails from last summer. They work great to keep the Suns rays off my Airstream.
Trees, tall building, even a large fifth wheel can cast a shade onto your Airstream from morning and/or evening sun.
Try to avoid parking your Airstream on concrete exposed to direct sun. A grass surface under and around the bottom of your Airstream will be allot cooler than concrete or black asphalt.
Floatingair is offline   Reply With Quote
Old 07-01-2016, 11:02 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes, grass is natures radiator.
Set your thermostat up, 80 or 85 would be a starting point, during the day so the unit is not trying to cool a 100 degree trailer when you come home from work.
2004 Excursion 4x4
Old 07-01-2016, 11:24 AM   #4
1994 30' Excella
Kiefer , Oklahoma
As for your Airstream, update the cool coat on the roof, install a on-demand hot water heat,
induction cook top, LED light bulbs, bubble wrap and/or silver foil on windows,
solar reflection window tinting, fiber glass insulation any open areas in floor cabinets to
block cold air loss, TurboKool (Swamp Cooler).
Air conditioning and the 30 amp circuit breaker in a 2014 27FB Rocinante Batteries, Univolts, Converters & Inverters 15 07-08-2014 09:37 PM
Full Timing & Timing, Sergei's Selling his ARGOSY Foiled Again General Interior Topics 8 05-18-2014 11:48 AM
Air Conditioning and batteries StevenG Boondocking 18 08-29-2011 11:45 PM
air conditioning cowling and vent disintegration Rickj Furnaces, Heaters, Fireplaces & Air Conditioning 7 12-30-2003 01:04 PM
