After no reply from Pole Ease, I decided to tackle making my own pair of flagpoles for my Safari. How hard could it be, right?
So the other day, I went to our local discount store and found telescoping golf ball retriever poles! Since they were only 10 bucks, I bought a pair.
I decided to cut the tips off (where the golf ball plastic thingumajig was attached to) with my handy dremmel.
I then inserted just the right size diameter plaster board retaining anchor at the tip where I then screwed into a couple washers and retaining screw with a washer that I drilled a small hole into which a retaining ring would then be inserted for the flag clip...
For the pole holders, I just went and got a pair of PVC pipes from Home Depot and cut them to size and secured them with retaining straps...
Works great! And stores within my side compartments quite nicely!
Total cost: less than 40 bucks!
Vinny
