Old 12-30-2004, 02:43 PM   #1
Trailerbunny's Avatar
Electrical storms
WoW, oh WoW !
We don't get to experience many electrical storms here in coastal Calif.
Last night the rain was pouring and the 30 mph wind had the old Argosy shaking...but the flashes of lightening and the kabooms had me shaking in my down booties...all I could think of was getting fried inside my tin can out here in this cow pasture....I wanted to unplug the electric cord to the trailer from the farmhouse...but didn't dare go out in all that....I did unplug all the appliances, including my electric blanket...
Have any of you experienced being in your AS in the middle of thunder and lightening?
Any suggestions for my next hair raising bootie shaking ordeal?
Trailerbunny is offline   Reply With Quote
Old 12-30-2004, 03:11 PM   #2
Tinsel Loaf's Avatar
Like aircraft that get struck by lighting the charge goes around the body of the plane.
The same thing would happen to your A/S. You most likely would not be toast, however there are no guarantees. There may be a weld mark left on the A/S.
Tinsel Loaf is offline   Reply With Quote
Old 12-30-2004, 03:28 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by Trailerbunny
WoW, oh WoW ! Have any of you experienced being in your AS in the middle of thunder and lightening?
Hello from the unofficial thunderstorm capital of the world, Florida. We get one every day, and sometimes more than one, all through the rainy season from June to September. If you want to avoid problems, a surge suppressor with antennae connections for your TV set would be helpful. Lower the antennae, lightning usually goes for the highest metal object in the area. You can turn the main breakers off in the rear, if you are concerned about a power surge into your trailer, just don't forget to turn them on again. Other than that, don't go outside in it.
Old 12-31-2004, 05:21 AM   #4
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Don't forget to roll-up or tie-down your awning before a T-storm. The strong gusts of wind may turn it into an airborne object.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
HELP! Electrical problem FranceyS Electrical - Systems, Generators, Batteries & Solar 6 08-03-2010 02:57 PM
Electrical problem--99 safari Andrew Carey Electrical - Systems, Generators, Batteries & Solar 2 11-16-2002 02:04 PM
electrical system 67 tradewind boardsander Electrical - Systems, Generators, Batteries & Solar 3 10-14-2002 04:32 PM
Wiring for electrical horn on 310 shelocta Airstream Motorhome Forums 3 09-03-2002 09:40 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
