Old 09-30-2006, 09:23 AM   #15
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've had both trailers and as pointed out by others environmentally the trailers are the same. Now that the SE Safari is available you can get the big Classic rivet windows. Some other items to consider, the Classic's may have bigger holding tanks when comparing against same size Safari's. Other ammenities in Classics like electric/gas water heaters, black water rinse valve, upscale toilet, better thermostat that controls heating and cooling, sofa is higher in quality, inside window treatments are usually curtains and dual mode shades, counter tops are higher grade, water filter built into kitchen faucet, entry steps higher quality, two fantasic fans standard, spare tire carrier standard, glass shower door, and awnings all around. Those are the immediate items that come to mind.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-30-2006, 12:45 PM   #16
_
Originally Posted by Minnie's Mate
There is a slide option on the Safari 28. It will add tongue weight but will also add to feeling of space.
slide model safari has been discontinued.
regards
2air'
Old 10-02-2006, 09:27 AM   #17
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Jack
The black water rinse valve, water filter kitchen faucet, higher grade entry steps, and spare tire are part of the LS package. I have an '06 30' Bunk with the LS package and these are all on my trailer.
regards
2air'
Hummm, it is still on the Airstream website. But of course so is the now defunct 30' Bunk. I would think they would update their site at least when the model year changes.
Family of Disney Fanatics
WBCCI# 4821
Safari :: 1996 Airstream Safari Land Yacht tlw12 Airstream Registry Discussions 0 12-18-2011 08:47 AM
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 06:37 PM
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 0 08-19-2011 08:32 AM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
