Old 09-08-2009, 02:45 PM   #15
astewart's Avatar
Stoney Creek , Ontario
An external antenna is better but with the higher frequency of cell phones, any obstruction causes problems. Wet leaves or rain are probably worse than being inside an airstream (lots of windows) as the higher frequencies are blocked in a manner similar to light (hence the "line of sight" issues with digital TV and satellite reception.
If you have a signal outside the AS then inside would also work well with the right setup (and an external antenna would help if marginal) but it really wonít help much if you donít have a signal to begin with.
astewart is offline   Reply With Quote
Old 09-09-2009, 08:15 AM   #16
snog's Avatar
springfield , Massachusetts
Silver- thank you for the link. i checked it out. indeed, my phone does have a port; this is where i insert the charger cable's male end when i charge the phone. also, it can be used as an usb port so i can use the phone to connect with my pc.
i imagine there would be somewhere on the outside of the mobile home that has metal, so i could just pop the antenna on it.
but, let's hope that i won't even need such a thing!
again, thankyou for your help!
got a phone here...it's got a little ring
snog is offline   Reply With Quote
Old 12-25-2009, 08:16 AM   #17
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Just download Skype...Skype is internet phone, where you can buy a number for thirty dollars a year. and the rates are cheap cheap cheap! and they include cam to cam phone calls too. Check it out, they give you a free trial at first to see if you like it. you need a headset though with a microphone. Bill
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 12-25-2009, 10:44 AM   #18
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
Something else to keep in mind, some models of phones as well as different manufacturers of phones will all work differently in similar circumstances...Maybe have friends with different phones hang out with you and check the quality of their signals...AND turning the phone off then back on will force it to find the nearest tower, something it MIGHT not do if its just left on...
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 12-25-2009, 11:01 AM   #19
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Originally Posted by overlander63 View Post
yada yada ............ because the trailer is a Faraday Cage.
And a good thing too! I saw a picture of an SOB once (which doesnt cage Faradays well) where the Faradays got out and TORE IT UP. Worse than a leaky window you don't know about.....
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 12-25-2009, 12:40 PM   #20
JLJustice's Avatar
1978 Argosy 27
Lacey , Washington State
We also have Verizon after having many of the other companies listed. It is the only one we have found that will do good service at home (urban) and in the country. The close tower to the house changes contract service priority about every year it seemed. The tower is close but "who" had priority to the tower seemed to be the issue. That makes me think I should buy some Verizon stock to help keep the company in business...[smile].
Judy (jjustice's wife)
WBCCI 3868
Washington State
http://www.youtube.com/Empresspublishing
http://thoughtsfromwisdom.blogspot.com/
JLJustice is offline   Reply With Quote
Old 12-25-2009, 07:25 PM   #21
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
They had probably fed their Faradays.
Vaughan
Old 12-25-2009, 08:32 PM   #22
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Our cell phone seems to do better in our Excella with the wrap around front windows than it does in the Caravel.
The same with WIFI.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 12-25-2009, 08:44 PM   #23
1983 34' Excella
1967 24' Tradewind
Images: 32
The same with WIFI.
Hi Jim,
Now that you mention it, that's my experience with my Excella vs the Trade Wind.
Vaughan
Old 01-01-2010, 02:38 PM   #24
BrockLives's Avatar
1972 29' Ambassador
Currently Camping , Pennsylvania
Bubblefoil insulation on the windows for winter cuts my indoor reception completely. But the aliens will never find me either. TINFOIL HAT!
BrockLives is offline   Reply With Quote
Old 01-05-2010, 06:04 AM   #25
Be Calm, Have a Cupcake
Secguru's Avatar
Houston , Texas
Excellent phone reception test
Dear Snog:
The best way to test reception when you go to the park is to find an aluminum clad trailer (any SOB will do) and while making a call walk slowly completely around the trailer viewing the number of bars you have from different sides of the trailer. The side with the weakest signal is away from the nearest tower. This may help you in selecting a spot for your Airstream that will give you the best signal. It's best to position the phone nearest the largest expanse of windows in the trailer.
When using an outdoor antenna, mount it towards the tower and with no aluminum reflections behind it.
Secguru
Would you rather have a mansion full of money or a trailer full of love?
Secguru is offline   Reply With Quote
Old 01-06-2010, 06:09 PM   #26
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville , Tennessee
[QUOTE=Secguru;790026]Dear Snog:
1) while making a call walk slowly completely around the trailer viewing the number of bars you have from different sides of the trailer. The side with the weakest signal is away from the nearest tower.
NOTE: This is not necessarly complete true, likely but not completely true, a cell phone is a radio and many things can interfere with the signal when moving to different areas.
2) It's best to position the phone nearest the largest expanse of windows in the trailer.
NOTE: This is always true the less obsticals for the signal will help the reception.
3) When using an outdoor antenna, mount it towards the tower and with no aluminum reflections behind it.
NOTE: This depends if you are referrng to the side of the antenna or the bottom, an aluminmum pie plate or the aluminmum of the AS under the antenna will act as a ground plane and help the reception of the signal. The signal does not radiate out to the sides but in a ball bounce manner, Ex is if you stood with a ball and bounced it off the ground about a foot in front of you is how the signal travels off all antennas.
Sarge KG4KWP
SARGE/AF is offline   Reply With Quote
Old 01-07-2010, 09:15 AM   #27
SJ1
Gwinnett County , Georgia
I live in a mobile home, ca. 1/2 mile from the cell tower. I get reception in the front yard and in the rooms closest to the tower, but there is very poor reception in the back rooms, and almost no reception in the back yard.
In the Airstream, the reception is best, in this neighborhood, when the phone is close to an open window or door. There is better reception in the Airstream than in the mobile home.
It seems that metal between the phone and the tower is a hindrance here.
In a campground in Florida, there was great signal reception in the Airstream with phones from various providers (Spring, Tracphone, MetroPCS).
SJ1 is offline   Reply With Quote
Old 01-07-2010, 10:06 AM   #28
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Lots of good info here. The main thing to remember is that not all towers provide coverage for all phones. The tower sites are carrier specific. This is why one carrier (Verizon, ATT, etc) may provide better coverage in a given area than another.
If you are moving to a new area and lose coverage, ask around to see what carrier provides the best service to that area. Bearing in mind, the carrier might fudge the answer a little. You can now keep your number even if you change carriers.
The amplifiers and boosters available do work, if installed correctly and there is some coverage to start with. A device called a Bi-Directional Amplifier could be installed in one’s trailer. Someone mentioned the brand name Wilson. I have used their stuff with success. They are on the web and easy to find.
Best Regards,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Cell phones while driving Pahaska Off Topic Forum 39 10-02-2006 05:49 PM
tv signal booster joel Electrical - Systems, Generators, Batteries & Solar 4 08-23-2006 11:05 PM
