Old 09-05-2013, 09:09 AM   #1
stellar1dan's Avatar
2013 27' FB International
Yelm , Washington
Best dehumidifier
Does anybody have any suggestions on the best dehumidifier for full timing? There tends to be a bit of moisture in the air around the Pacific Northwest in the winter
stellar1dan is offline   Reply With Quote
Old 09-05-2013, 10:33 AM   #2
Zigidachs's Avatar
2011 30' Classic
Ridgefield , Washington
We live in Oregon, so we understand!!!!
Take a look at this product...which we use when we are on the road. Seems to work quite well, and there are different models, depending on needs.
Amazon.com - Eva-Dry Edv-2200 Mid-Size Dehumidifier
Zigidachs is offline   Reply With Quote
Old 09-05-2013, 10:50 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I started using this just a few weeks ago. Danby Dehumidifier ADR30A2G
It does a great job removing humidity. It will take the relative humidity in my trailer down below 40% easily. It removed more than 2 gallons of moisture the first day I ran it in my trailer. (had a leak with wet floor) It has an external drain, so you do not have to tend the drain bucker. The down side: it gives off heat inside the trailer (as any dehumidifier will)
Make sure that the unit you get will come back on after the power goes off. I bought a prior one from Sears that does not.
Alan
Old 09-05-2013, 03:19 PM   #4
Air Apparent's Avatar
Northern Illinois , Illinois
Here is another one to look at.
http://www.controlmastersinc.com/marine_dehumidifiers.htm
Dave
2008 Classic 34
Dodge Ram 2500 Quad Cab CTD
AIR #7317 WBCCI #1772 TAC-IL 1
Air Apparent is offline   Reply With Quote
Drips - Dehumidifier info Needed hoofer Full-Timing 11 02-25-2012 12:58 AM
Do I need a dehumidifier or heater in storage? GaRoc Winterizing, Storage, Carports & Covers 12 02-03-2012 04:23 PM
Best 12V Dehumidifier palmer51 Winterizing, Storage, Carports & Covers 1 11-04-2011 10:33 AM
Rock Salt Dehumidifier Bluto Dehumidifiers & Ozone Generators 6 06-03-2011 04:51 PM
Dehumidifier - Recommendation Please - bugnot1 Winter Living 5 02-27-2011 12:37 AM
