Hi there! My full-time Airstream living is about to begin, and I am so excited! (I love all of the smilies by the way!) The AS is parked and will not be used for travel. I am hooked to electric and water, but not on septic. I am interested in installing an Air Head toilet. I have done some research and have seen nothing but positive reviews. However, I am hesitant because my mom had a terrible, TERRIBLE experience w/ a composting toilet in her house. The one she had did not separate liquid from solids. My main concerns are:
1. Flies 2. Smell 3. Amount of time that will be spent caring for my waste (hope I don't gross anyone out with that, but it was the easiest, bluntest way to word it)
Please, please, please reply to this post if you have experience with an Air Head toilet. It will be very and gratefully appreciated!
Thanks! AS Girl
I'm not so sure what an air head toilet is but I installed a dometic vacume toilet in my 56 caravanner. The waste is drawn into the vac tank and then pushed up into the black water tank. No smell whatsoever. The system also has a marine vent filter so there are no smells coming from the vent pipe either.
No cheap but a very good system.
D
56' Caravanner 'The Broomstick'
From what I understand these toilets separate the solids from the liquids, then compost the solids. What do you plan to do with the liquid waste as well as the grey water if you have no sewer connection?
The thing to remember with composting toilets is that if you cover them properly with enough carbonacious material (i.e. fine sawdust, etc.), they will have no foul odor. The cheapest way I have ever heard of doing a composting toilet is a 5-gallon bucket with a toilet seat on top. You have another bucket of sawdust with a scoop. Each time you use the toilet, you cover the waste with a layer of fine sawdust and then replace the lid. When the bucket is full you dump it appropriately, and there should be no foul odor. There are several articles and resources I could send you if you are interested. The Tiny House guy has an article about living in an Airstream without sewage hookup for a year or so.
As a matter of fact, my mom started using the "Loveable Loo" about a month ago. It has been interesting,but great. Thanks so much for the reply and I would love to see the articles you wrote about!
Yep, installed an Air Head in my sailboat prior to sailing along the East Coast and Bahamas.
Easy to install ..... I used a solar powered vent instead of the 12 volt he recommends, though the 12 volt may be easier with the Airstream. The liquid container/collector required a trip to dump it about every two days, though there is a way to add a larger collector, but I do not remember how.
Did not ever get the offensive smell you might thing, but occasionally did get a slight swampy odor and added more compost when than happened. Do not know if this was because it was on a boat, or that was normal.
