02-06-2013, 10:57 AM
1988 32' Excella
Robbinsville
, New Jersey
Originally Posted by Protagonist
And, of course, duct tape, the one-size-fits all solution to everything from auto repair to mending clothes. Sticking it to your face and pulling it off fast because you forgot your razor is NOT recommended, however!
I supplement duct tape with electrical tape and 3M heavy duty packing tape.
Electrical tape for electrical.
3M heavy duty packing tape anywhere you would use duct tape then spend an hour or more trying to remove the adhesive residue from the duct tape. Been there, done more then enough of that.
02-06-2013, 11:08 AM
OregonCanuck
2012 19' Flying Cloud
Portland
, Oregon
The local AS dealer service department recommends 120 psi in the 19' Bambi's so the 100 psi tire gage that was listed is about 20 psi short of this recommeded psi.
02-06-2013, 11:15 AM
1995 30' Excella
Bowie
, Maryland
That sounds a little high... my bicycle tires don't even go that high.
1995 Airstream Classic 30' Excella 1000
2006 F-250 6.0L Powerstroke Supercab
Sold but not forgotten: 1991 Airstream B190
02-06-2013, 12:47 PM
1988 32' Excella
Robbinsville
, New Jersey
Please post your tire size and type, I never heard of a tire pressure that high for an Airstream travel trailer. A picture of the sidewall max PSI would be nice to.
02-06-2013, 11:06 PM
2012 Interstate Coach
Los Gatos
Some other things I would add are
- zip ties (aka wire ties)
- selection of hose clamps
- selection of adhesives (I have some single use tubes of super glue and gorilla glue)
- stainless steel bailing wire
- in addition to the tire repair kit, I also carry a can of fix-a-flat
- pair of leather work gloves
I carry a fair amount of other stuff too, but I would consider the above to be part of my 'basics'.
BTW, I fit all of my stuff into a medium sized pelican case. My goal is to have everything I need, but not excessive amounts of it. If you are wise about what you choose, you can get the essentials into a small box.
02-07-2013, 06:11 AM
1968 24' Tradewind
Rural, blink and you'll miss it
, Missouri
I second this choice of tape.
And in the first aid kit: tampons and/or sanitary napkins. They make great bandages.
I also think a couple of disposable infant diapers are great. Multiple uses. Absorb leaks. Can be used as hot or cold packs. Reusable if clean water is used. Just let them dry out.
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
02-07-2013, 06:26 AM
#21
Metairie
, Louisiana
Disposable diapers are VERY useful for tow vehicle or generator oil changes. Place a diaper under the oil filter as the filter is being removed to catch drips, then set the filter upright on the diaper to drain. Use the diaper to mop up spilled oil, too. Liquid oil is considered hazardous waste, but oil soaked into a diaper is considered non-hazardous solid waste and can legally be tossed into any dumpster.
WBCCI #1105
TAC LA-4
"In a perfect world, I'd be given enough time to wrap up one emergency before the next one starts." Freefall2013
02-07-2013, 07:16 AM
#22
Tonganoxie
, Kansas
I only carry 100 psi in my semi tires.
02-07-2013, 11:11 AM
#23
2012 30' Flying Cloud
Marthasville
, Missouri
Maybe it was mentioned earlier and I missed it, but we also carry ant spray. On summer trips, we've found the ants soon find the rv tires and sometimes work their way into the rv. Spraying around the wheels and stabilizers helps keep them away. Greasy BBQ pits also helps attract them.
AirEgger
02-07-2013, 03:20 PM
#24
Albuquerque
, New Mexico
This Comes Closest to My Response
Originally Posted by pappy19
I pretty much carry all of the listed items except only one bucket. I have an extra 25' of 30 amp cord in case the parking spot is a little too far. I also carry 2-50' 110 extensions and a "tire aide" in case I need to change a tire(now that I am about to replace my 15" ST to 16" LTX, I hope no more problems with tires).
Pap
I have used everything on the list plus:
Duct Tape
The Tire Aide
Torque Wrench
120 VAC outlet tester
Multi-meter
Cordless drill with adapter for BAL Jacks
Etc.
Ken L 2007 Classic Limited 30
2007Chevy Silverado 2500 HD Duramax/Allison Four Corners Unit WBCCI #8654, Affiliate NM Unit
03-16-2013, 01:40 PM
#25
Fuil-Timers
2005 25' International CCD
Everywhere
, North America
Great posts! And a great practical list for essentials. We use everything on the list except for the few items listed in "we do not carry" below.
We carry also:
1. a portable air compressor (110v since we have a small genset too);
2. both flares and reflectors;
3. 50amp and 15amp adapters
4. caulk and rescue tape
5. a 6' X 16' breathable area rug (doesn't kill grass)
6. awning tie-downs
7. WX radio
We do not carry:
1. quick-connect for water hoses, just never needed them
2. holding tank cleaners or deodorizers, we just dump when near-full
3. HD flasher relay, I agree it is a great idea and we are getting one
4. cross-type lug wrench, but we have ample means to loosen/tighten lug nuts
And we do not use:
1. stabilizing jacks, just don't need them (well, we did put them down three years ago in New Mexico for very high winds at our beam.)
| Thread Tools |
| Display Modes |
